parafeed - Gyrator vs CCS anode load - Page 2 - diyAudio
Old 20th November 2010, 10:45 PM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by Bigun View Post
Nice design Wavebourn.
I'm curious (still learning, as ever), why did you opt for a tube (V2) as buffer to drive output tube if you allow sand in the game you could also use a source follower ? or even use another gyrator for the cathode load for V2 ?
Source follower would add own capacitances. I tried to minimize them.
Here is one more version, without gyrator:
http://wavebourn.com/forum/download.php?id=494&f=7
You can use 6P1P there instead of 12L6GT, with 2K7 cathode load resistor.
The Devil is not so terrible as his math model is!
Old 21st November 2010, 12:41 PM   #12
adamus is offline adamus  United Kingdom
wavebourn, you may have to forgive my lack of knowledge here... but will something like this work
Old 21st November 2010, 12:56 PM   #13
bigwill is offline bigwill  United Kingdom
That will work, all I'd do is make R1 bigger and in real life use a zener from the gate to source to protect the gate from overvoltage
Old 21st November 2010, 01:02 PM   #14
Oh, and you can take output directly from the source to get a lower output impedance, which is nice!
Old 21st November 2010, 02:27 PM   #15
A question about the zener: it is commonly applied to protect enhancement mode mosfets, but will it also work with depletion mode mosfets, as the DN2540 discussed here?
erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 21st November 2010, 02:37 PM   #16
erik
I'm not sure! I forgot DN2540 was depletion mode. It won't hurt, but I'm not sure what protective role it will have. You might need one the other way around with depletion mode FETs, to protect the gate from excessive negative voltage with respect to the source. Someone more knowledgeable than me will be able to answer this.
Old 21st November 2010, 03:14 PM   #17
zigzagflux's Avatar
I put in back to back zeners as insurance in either direction, and have had good results. Some of my designs seem to place tough conditions on the FETs, during startup conditions when the tubes aren't sufficiently heated. Lost a few of them until I installed the zeners.
If I recall they were 9.1V; during normal operation most of my CCS's run with a volt or two on the gate, so there is really no effect when installed.
Old 21st November 2010, 03:23 PM   #18
Back to back seems to be the way to go then, for either type!
Old 21st November 2010, 03:24 PM   #19
Wait - This will limit you to 0.7v on the gates due to the forward voltage....
Edit: Ignore me, back to back is not anti-parallel
Old 21st November 2010, 03:45 PM   #20
Bigun is offline Bigun  Canada
Bigun's Avatar
How does this gyrator design compare with using a choke load ? I have recently found out that Edcor output transformers are as cheap as $17 each, which in your application would remove the need for many components and provide safety isolation for your headphones against any danger of B+ appearing at the output. Simpler to wire up, no heatsink and could allow a lower B+ depending on how much is being dropped across the gyrator. The only downside I can see is that your B+ needs to be a lot cleaner since PSRR is lower with the choke.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
New PNP HV tranny for anode CCS richwalters Tubes / Valves 12 8th November 2010 11:35 AM
Rod Coleman CCS/gyrator help zigzagflux Tubes / Valves 14 7th March 2010 12:40 AM
CCS or V.REG for OP anode pointy Tubes / Valves 0 20th January 2010 12:25 PM
chocke anode load, please explain me.. inertial Tubes / Valves 7 20th February 2009 12:47 PM
LL1673 as anode load? walkwalk Tubes / Valves 1 13th July 2005 03:04 PM
Copyright ©1999-2017 diyAudio
