Have you seen their curves?
Here are curves of 4P1L: less than 2K in triode mode, 10 mA/V
Hi everybody
Thank you for proposals. Some replies to all in one post
1. 6C45P - I found several schemes about it but in reality it was only 0.5-1W in single stage amplification that is not enough for me. Similar schemes are for 6J51P, 6J52P. The are good for preamlifier or amplifier for computer (in this case it might be done as a single tube). Will make look at your variants at weekend. SRPP might be a good idea (1.5W)
2. It is intersting idea from Wavebourn. At the moment I am finishing SE amplifier at 6S2S + interstage trans + 4P1L. Will make some posts about it later. But idea to use 4P1L as single stage is interesting.
3. Other ideas will lok at weekend and reply.
Thank you all.
Thank you all.
The problem with this tube is too low gain. Almost 3 Vrms is required to drive to 3W out. Therefore higer gm pentode is more suitable.
(like 6Ж52П, = 6J52P)
The advantage of needing 3 voltsdrive for full power is that you won't over drive it with typical CD players.
I've built 3 of them and never had any gain issues.
I do not see the low sensitivity as any advantage.
The danger of possible over drive by a high output CD-player is avoided with volume control ofcourse.
But if the music source happens to be a low output MP3-player with 0,7 V for example, then the amplifier with 3 V input sensitivity is quite useless.
So as we still discuss about single tube amplifier, the higher gm-tube is an advantage.
The 4P1L is direct heating tube.
You need a 1:4 trans at the input in single stage 4P1L option.
This weekend I launched my 6S2S+interstage trans+4P1L project. First impression is exellent and very detailed sound (better then my 300B based SE) but with low power 2W per channel. So one need horn speakers for it. But to go forward for single stage is a good idea. Will look for good input trasformer for it. For such minimalistic design qualiti of input transformer is very important.
Your 6j52p suggestion is great until you look at the anode dissapation. It's a little light, not good for a SINGLE tube amp, as in the case of this discussion. You'd want something bigger like a 6C45pi with closer to 8w plates.
I don't see your point. Please try to make me understand.
The Pa max. for 6S45P is 7,8 W and 10 W for 6J52P.
Actually I do not even know (so far) any better valve for single tube amplifier than 6J52P.
Two other good candidates are:
- E810F (Pa = 5 W, gm = 50 mA/V) and
- WE437A (Pa = 7,0 W, gm = 46 mA/V)
Compared to 6J52P ( Pa = 10 W, gm = 55 mA/V)
In my opinion, the optimal tube for a single tube amplifier is such that has as large gain as possible combined with as high anode dissipation as possible .
The datasheet I saw on the 6j52p had 5w plates, guess my russian is not up to spec.
How about a tube George mentioned in the 20W single tube thread.
"The 6HV5A and relatives. Transconductance is 65000, Mu is 300, plate dissipation is 35 watts. The plate is big enough to eat a bit more than 35 watts. So. it's a done deal, right? Not so easy. The tube needs a bunch of voltage, and it's plate resistance is real high, so feedback is almost mandantory. I have experimented a bit with this tube and have yet to tame it. Good luck! "
Sounds like it would be an interesting canidate that would need more experimentation, but the possibility of over 15watts output on a single tube is tempting.
Very high voltage might be a problem from technical side. Especiallty for power supply. The only option I know in this case to use power supplies from microwave oven. But they get around 2000 V output.
Hi!
After many years of absence, I decided to join DIYaudio again. I just saw this thread about the single tube amp and the 6HV5A was mentioned. I used this tube and it's relatives (6HS5) for various amps and preamps in the past. Just recently I published a schematic in another forum.
Here is the schematic of the amp with the 6HS5:
ImageShack® - Online Photo and Video Hosting
The required B+ can be done with a voltage double PSU:
This amp gives 7-8 W SE. It requires about 2,7-2,8V RMS on the input for full power.
Here are some pics of a finished amp with this tube:
This concepts scales well for PSE operation.
Here a pic of a PSE stereo amp besides a SE:
Recently I finished a PSE version with 4 6HS5 in parallel with 30W per channel. These have been built as monoblocks:
If there is interest, I'm happy to share more technical details.
Best regards
Thomas
Best regards
Thomas
Hi!
Thomas
Hi Thomas.
Could you get more info about transformers? For me it is the biggest question since I do not make them by myself.
Michael
Hi Michael,
So far I built this concept with two types of output transformers. One is the Tango FE20-14S. The second is the Lundahl LL2735B. Lundahl developed this transformer after me requesting it and I had the opportunity to evaluate the first engineering samples.
The chokes I used are Lundahl but others could be used as well if they have the proper insulation rating for the high B+
I get the power transformers custom made to my specs. That is a universal power transformer with several taps which I use in all my power amps. Any power transformer with similar voltages could be used. Important to observe the insulation rating of the heater windings! One of them needs to be tied to B+
Note: Please be aware that I'm running a small business as a side job, offering parts, kits and fully assembled amps of all of my projects. But a lot of my designs like this one are public domain and the schematics are published on various forums free for anybody to use.
Best regards
Thomas
Best regards
Thomas
6Ж52П were made according to 2 different specs: for military applications -- lower Pd, lower noises and microphonics, and for civil specs for TV video amplifiers: higher Pd was allowed. But as far as I know, they were dying young in TV sets. I used to swap them in TV receivers by 6P15P sometimes, that were cheaper and wider available; with lower amplification factor, but higher anode dissipation rates.
Hi Michael,
Best regards
Thomas
Hi Thomas
What about input sensitivity of this amplifier? Is it 2V?
Hi Thomas
Sorry, I found in text "2,7-2,8V RMS on the input for full power."
But is it possible to use input transformer 1:x to decrease RMS to 1.5-2V?
I have one with 1:10 rate.
Michael
Hi!
The difference between 2V and 2.8V sensitivity is a mere 3dB.
Yes you can increase the sensitivity with an input transformer. A 1:2 transformer would bring it to 1.4V input for full power. However make sure your preamp is able to properly drive the input transformer.
Most preamps have way too much gain anyways, so a less sensitive power amp can be beneficial.
Read up my artice about gain, headroom and power on my blog about this.
Best regards
Thomas
Best regards
Thomas
I think the 4L1P can be an interesting alternative (triode or pentode).
Someday I'll try.
I writte better than chitah
- Tubes / Valves
- Look for Single Tube scheme
