Possible tweak - Page 2 - diyAudio
Old 19th November 2010, 04:38 PM   #11
max29 is offline max29  Netherlands
The EML 20b -crazy priced.- was only as example to find out the gain it gives and compare to the 2A3..
The 1k is in series with the output 2A3 grid not in parallel with the IT.
To picture it...
So on the sec side of the IT:
The upper pin for the - 45 fixed bias and the
lower pin to the resistor to the grid of the output tube.
Drawn a schematic so you see...
Old 19th November 2010, 05:07 PM   #12
kevinkr's Avatar
I don't see the schematic posted..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
let's tweak this amp!!!!! Flavio88 Solid State 34 14th August 2006 06:50 AM
Tweak for the FE206E usa_satriani Full Range 15 27th April 2006 10:52 PM
The Ultimate Tweak SY Everything Else 8 25th May 2005 11:52 AM
new tweak? mirlo Everything Else 1 21st May 2004 11:02 PM
Anybody tried this tweak? Is it worth it? Music Machine Everything Else 20 26th May 2003 03:41 AM
Copyright 1999-2017 diyAudio
