| diyAudio Sponsor | ||
Can I sub a 50l6 in a circuit that uses a 50c5 without changing other components? I have studied their data-sheets and it appears to me that it would be ok? Any advise greatly appreciated...
Thanks, Nick |
#2 |
Similar but different pin-out. 50L6 has higher max ratings. You'd have to rewire the socket.
#3 | |
Here's the circuit that I'm working with... |
#4 | |
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#5 |
Yep, you have to change it all to octal sockets. Filament voltages and currents will be the same.
#6 |
Thank ya'll very much, just the information that I was looking for...
Thanks, Nick |
| opinions on a 12at6 headphone amp | kuroguy | Headphone Systems | 3 | 9th April 2008 02:10 PM |
| grounding and 12AV6 diodes | PRNDL | Tubes / Valves | 1 | 19th May 2007 07:37 PM |
| 50C5 conversion | PRNDL | Tubes / Valves | 17 | 10th May 2007 07:54 PM |
| 50C5 Triode strapped? | ThSpeakerDude88 | Tubes / Valves | 4 | 10th March 2007 03:31 AM |
| 50C5 add-on amp | tubbytwo | Tubes / Valves | 7 | 25th November 2004 08:01 AM |
| Page generated in 0.09525 seconds (73.63% PHP - 26.37% MySQL) with 11 queries |
