What tube is this?
I cant seem to figure out what tube this is.
It has the philips etching code, but the top row (wich indicates tube type) is unreadable.
It looks like an EF80 but the inner cunstruction is twice the size.
EF80 Country: Europe
Brand: Common type Europe tube
Tube type: Vacuum Pentode
RF/IF-Stage
Tube ID = 709
Identical to EF80 = 6BX6 = Z719 = Z152 = 8D6 = 64SPT = 6P6_Magnadyne
Similar Tubes Normally replaceable-slightly different: 6EL7
Heater different: 12BX6; UF80; XF80
First year 1951 Tube leaflet collection E.Erb Analysis by original leaflets
First Source (s) Jul.1950 : Radio-Mentor # 7
Predecessor Tubes EF42 EF50 EF14
Successor Tubes 1960 EF184
Base Noval, B9A
Was used by Radio/TV-reception etc.
Filament Vf 6.3 Volts / If: 0.3 Ampere / -: Indirect / -: Parallel / series AC/DC /
Dimensions (WHD)
incl. pins / tip 22 x 68 x mm / 0.87 x 2.68 x inch
Weight 20 g / 0.71 oz
