Signal tube noise! Signal tube noise! - Page 2 - diyAudio
Signal tube noise!
Signal tube noise!
Old 16th November 2010, 05:51 PM   #11
M Gregg is offline M Gregg  England
I think the H-K leakage as you say is the most probable!
You have got me thinking now I wonder what will happen if I reverse the DC on a "bad" tube?
Other guys use DC filaments I don't hear them having this problem.
Old 16th November 2010, 05:54 PM   #12
20to20 is offline 20to20  United States
20to20's Avatar
Originally Posted by M Gregg View Post
I have had it happen to 3 tubes now NOS RCA, Mullard, Now Groove Tube. The voltage is spot on 6.3V DC.
I had a 12ax7 make a kind of hissy, sizzly, muffled poping noise. Not constant but aggrivatingly too present. I swapped sockets and it was there. Tossed it.
I've also had a dirty socket, and tube pins sound like that too. But wiggling the tube gives that one away.
Old 16th November 2010, 06:00 PM   #13
The tube seems to go microphonic and noisy! If you tap it the sound comes and goes! I have changed the socket " Still the same. I thought it was an Elec cap so I changed that too! Its a recent build. I would bin the circuit, however I want to know whats happening might I come across it again!
Old 16th November 2010, 06:01 PM   #14
20to20's Avatar
Since a good tube will usually work with a lower filament voltage, you might try dropping a volt to it if you can, for kicks, to see if it makes any difference at all.
Old 16th November 2010, 06:07 PM   #15
If I'm honest its driving me nuts. LOL I just got to know why it's happening!
I will try a few things.
Old 16th November 2010, 07:18 PM   #16
Sheldon is online now Sheldon  United States
I find it "sounds" better with DC filaments. I must admit this has got me puzzled! Someone said to me in the distant past that the heater can age in a non uniform manner with DC. I don't want to post old wives tales, it's probably a load of hog wash.
That can possibly apply to DHT's because the filament carries the signal current as well as the heating current. The positive side of the filament will carry more of the load than the negative side. Probably only an issue when tubes are run near current limits.
With a IDHT, the heater is not part of the cathode current flow, so this would not be an issue.
Sheldon
Signal tube noise!Hide this!Advertise here!
Noise from new caps in signal path, please help! rg12 Parts 7 27th August 2010 02:13 PM
Lowering noise in small signal pentodes? leadbelly Tubes / Valves 34 10th February 2010 06:34 AM
Signal Indicator LED Noise? turantual Solid State 4 15th August 2008 11:13 AM
noise floor w/ and w/o input signal gearheadgene Class D 18 6th September 2006 08:04 AM
Informative article about signal interfaces and noise Arius Parts 0 13th July 2006 05:56 PM
Copyright ©1999-2017 diyAudio
