diyAudio Sponsor
Old 15th November 2010, 01:09 AM   #1
Default Stromberg-Carlson AU-32 distortion in preamp
Hello all,
I've been reading for a while, but this is my first post.
I've got an SC AU-32, which I am updating and optimizing for guitar. So far I have added a grounded cord, replaced most of the caps, (including rebuilding one of the cans) and changed out the inputs and outputs for 1/4" jacks. I added a selector switch to select the output impedance.
It's working and sounds great, if you keep the volume under 3. Above that it starts to distort, much sooner than it should.
I pulled out the o-scope and hooked it up with a sine wave input. Through the input tube (6SN7) all is good, nice symmetrical amplified signal.
The distortion shows up at the input of the mixing tube (6J5). The two input channels are tied together with 1M resistors, tied together, with the junction fed to the mixer tube.
On the input side of the 1M resistor, I see a nice symmetrical sine wave. On the output side of the resistor, I see a clipped signal.
And there I am, out of my depth. I don't see how the signal is becoming asymmetrical across the resistor.
The only caps I didn't replace are in a can with 3 10 uF caps, one of which is circled on the schem photo. This hookup is confusing, since the cathode resistor/cap are connected not to ground but to the B line. Any ideas?
FS: Stromberg Carlson AU-57 tube amp whitelabrat Swap Meet 8 18th December 2010 05:26 AM
strange Stromberg Carlson m6tt Tubes / Valves 1 11th January 2010 06:56 PM
Converting a Stromberg Carlson AU-35 into a Bass guitar amp? Pckid212 Tubes / Valves 14 30th November 2009 10:10 PM
Stromberg-Carlson project majorarmspeed Tubes / Valves 55 12th June 2009 07:46 PM
Stromberg Carlson speaker...please help. the_manta Multi-Way 5 7th March 2007 02:20 AM
Page generated in 0.06200 seconds (71.29% PHP - 28.71% MySQL) with 11 queries
