diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   EL34 PP PROJECT (http://www.diyaudio.com/forums/tubes-valves/177257-el34-pp-project.html)
el156 14th November 2010 02:55 PM
EL34 PP PROJECT
4 Attachment(s)
Here are so fotos of my latest project...
E88CC as input tube
ECC804 as phase splitter
M Gregg 14th November 2010 03:09 PM
el156,
Nice project!
Palustris 14th November 2010 08:27 PM
I love the curved front and the overall design.
richwalters 15th November 2010 07:57 AM
Youre lucky getting rid of the heat isn't an issue.
el156 15th November 2010 08:36 AM
Well, it is a newbie project,but i am not very happy with the sound ,it seems doesnt have enough power, but i will post the schematic to get your opinion about it, maybe i havesome mistake in there!
Thank you for your comments
EL156
richwalters 15th November 2010 10:58 AM
30W o/p with a pair of EL34's should be a breeze. Using 92dB/w LS sensitivity with good sized bass drivers should rock the room. This was a standard classic design of the 1960's and found amps of this everywhere in halls and theatres.
richy
artosalo 15th November 2010 12:53 PM
Do you mean that the sensitivity is low, which means that your input signal can not give full output ?
Or do you mean that the output signal becomes distorted before the sufficient sound level is achieved ?
Can you show the chematic ?
el156 15th November 2010 01:25 PM
Originally Posted by artosalo (http://www.diyaudio.com/forums/showthread.php?p=2365865#post2365865)
I think sensitivity is ok , the signal comes distorted before sufficient sound level is achieved, I have to draw the schematic first to post it later on or tpmorrow.
EL156
el156 20th November 2010 05:15 PM
1 Attachment(s)
Okay ! Here is my schematic ! Maybe someone can tell me what is wrong with this schematic !
EL156
Sorry for the bad quality of pic
toprepairman 20th November 2010 06:20 PM
EL34
Fair circuit so should work ok. I note there is no negative feedback so speaker impedance will have a big impact on the frequency respose (as per a typical guitar amp/combo) and matching the speaker impedance to the reflected output impedance will cosiderably affect power output. As a general rule you should load a typical 8ohm speaker to a 4 to 6 ohm tap to account for speaker impedance dips.
With the 380 volt supply I wouldn't expect much more than around 20 watts.
Here's another note for any other builders of ultralinear EL34 designs, you should never exceed a max of 420 for the HT, otherwise you will get flashovers between the screen grid and control grid, very nasty.
Incidentally this is my first posting on this site.
Copyright 1999-2017 diyAudio
