diyAudio Sponsor
Old 21st July 2003, 02:30 PM   #11
jeffreyj's Avatar
Originally posted by Sch3mat1c
Any transformer will tolerate DC. Period. How much depends on construction.*
Tim
* italics mine
I agree. Put an air gap in the main flux path and you can put all the dc through the transformer the wire will allow. But I didn't say a regular old transformer couldn't tolerate DC, Tim, I said such would affect the AC performance parameters.
No matter how you slice it, saving a penny by omitting the reverse biased diode across the LED is poor engineering. It may not degrade performance much practically speaking, but why let it occur in the first place if the solution is so simple?
Before you make that audacious claim, check this site out:QAudio Myths
Power supply cap brands & Specs Zero Cool Everything Else 16 30th October 2010 07:22 AM
FS: chip amp power supply and xformer madisonears Swap Meet 3 3rd March 2009 05:39 AM
Power supply inductors (what specs?) BrianGT Pass Labs 56 20th July 2008 11:48 AM
Heater Power Supply Pspice model ece Tubes / Valves 0 17th July 2007 08:27 AM
Heater power supply help BillyF Tubes / Valves 8 28th August 2003 10:58 AM
Page generated in 0.07299 seconds (67.41% PHP - 32.59% MySQL) with 10 queries
