diyAudio Sponsor
Old 14th November 2010, 01:15 AM   #1
dtm1962 is offline dtm1962  Canada
Default 6922 Loading Question
I have a heavily modified Lite 60 (Monarchy NM22 without the preamp) and I was wondering what is an acceptable load (Preamp) to allow the 6922 output tubes not to be overloaded.
I have a NAD S-300 (built by Gryphon in Denmark) that has a passive preamp (no active components prior to the potentiometer) and a 10K potentiometer. I believe this load is too much for the Lite 60 6922 tube based output.
I sense a little distortion in regards to overload....
I wanted to replace the 10K Blue Velvet Alps with a 50-100K potentiometer to lighten the load for the 6922's.
What are the consequences in regards to changing the pot from 10K to 100K?
Any help would be appreciated.
Thanks,
Dan
Old 14th November 2010, 10:50 AM   #2
DF96 is offline DF96  England
Less distortion, more noise. How noticeable this would be depends on signal levels.
Isobaric loading question IG81 Multi-Way 5 26th April 2009 09:46 PM
6922 as a CCS, a question ? Shoog Tubes / Valves 12 11th April 2004 07:36 PM
quick question about a sovtek 6922 elizard Tubes / Valves 2 17th January 2004 08:43 PM
MM Cartridge loading question gurevise Analogue Source 7 16th December 2003 12:30 PM
Basic question on 6922 ghee0 Tubes / Valves 3 24th January 2003 03:55 PM
Page generated in 0.07029 seconds (70.67% PHP - 29.33% MySQL) with 10 queries
