Back at the 45 SET - Page 4 - diyAudio
Old 27th November 2010, 09:08 AM   #31
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Originally Posted by mltube View Post
Just a sample of tubes I have rolled into this experiment...
These are matched pairs (quite close)..
Hi Mike,
I managed to get hold of a set of 26s, on their way from the US at the moment
Was keen to see your latest circuit updates and results particularly on the driver stage?
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 27th November 2010, 10:23 AM   #32
artosalo's Avatar
Have you measured your stereo separation?
Is this an over estimated feature ?
I looked the specification of hi-end MC-cartridges and those have some 25 dB stereo separation in average.
Old 27th November 2010, 10:42 AM   #33
Vinylsavor's Avatar
Hi!
The 45 belongs to my favorite tubes. The 27 is a great choice as driver, albeit maybe a bit low in gain, but if the system has enough gain it's great. I had a 27/45 in the past and spent a step up input transformer to get a bit more gain. I have a 45 amp in my commercial offering and there I use a 6N7 (both sections paralleled). That gives just the right gain. The 6N7 is a great tube which gets less attention than it deserves, maybe because the two halves need to be used in parallel (they have a common cathode). Good for me because that keeps the prices low
I plan to take a 26/45 into my amplifier lineup. Will start construction soon.
One caveat about mesh 27s. I tested many on a curve tracer and found that a lot of them have very irregular plate curves. Often the electrodes are misaligned which causes this. The ST shape 27s I measured all had very linear curves.
here some pics of my 45 amp, stereo with external PSU:
ImageShack® - Online Photo and Video Hosting
Best regards
Thomas
Old 27th November 2010, 10:47 AM   #34
Vinylsavor's Avatar
Hi!
IMHO yes! I get often the question why I rarely build mono amps but rather stereo with external PSU. As was mentioned before MC cartridges typically have very low channel separation, so that a few dB less in the amplification does not really matter.
I think the sound degradation which people observed with common cathode resistors between channels is not related to stereo separation. I always spend separate cathode resistors even in PSE amps for each tube. So each tube finds it's own optimal op point. With shared cathode resistors the tube with more emission hogs most of the current and the other one is left 'starving'
Best regards
Thomas
Old 27th November 2010, 05:10 PM   #35
Sheldon is offline Sheldon  United States
Yes, in my opinion too. I started out building amps with separate power supply or supply finals for each channel. Later testing showed a small amount of crosstalk with a single supply, but I could not hear the difference. If I split supplies now, it's between stages, not channels.
Same is somewhat true for bias supplies for a fixed bias amp. I use a single supply, and split it before the final RC if I need to reduce crosstalk. But I no longer try to reduce it to zero.
It's simple to test. Run an input into one channel and measure the signal level. Compare that to the undriven channel. If you are 35-40dB down, there's not much to gain by trying for 60dB.
Sheldon
Old 27th November 2010, 06:45 PM   #36
This makes good sense and is probably a major contributor to why I tend to dislike the sound of SE amps using this arrangement.
Old 5th December 2010, 10:05 PM   #37
mogliaa's Avatar
I managed to get hold of some 27s, they don't have a lot of gain though, what is the best driver circuit for the 45?
Ale
Old 6th December 2010, 08:27 AM   #38
Vinylsavor's Avatar
Hi Ale,
as I mentioned in my post above, 6N7 works nicely for me.
Best regards
Thomas
Old 6th December 2010, 10:03 PM   #39
mogliaa's Avatar
Hi Thomas,
Yes 6sn7 is a great valve for phase spliter, problem is that I have only one, and can't find any cheap Similar ones around.
I originally considered a 6sl7 in a symmetrical totem pole configuration or similar which can easily give a gain of 27db
Ale
Old 6th December 2010, 10:19 PM   #40
Vinylsavor's Avatar
Hi Ale,
I meant 6N7, not 6SN7.
Thomas
Building a 45 SET livingdeliberately Tubes / Valves 19 2nd August 2010 06:25 AM
Simple 5842-45 SET Amp Design Idea eeyore Tubes / Valves 41 10th March 2009 11:48 PM
WTB: SET 45 tube amp tnc Swap Meet 5 13th February 2009 10:32 PM
back after a long time amo Multi-Way 2 1st May 2008 12:56 AM
What 45 SET amp should I build? raver Tubes / Valves 3 30th January 2005 03:38 PM
Copyright 1999-2017 diyAudio
