Back at the 45 SET - Page 15 - diyAudio
Old 25th January 2013, 10:58 PM   #141
pieroh is offline pieroh  Germany
Hi Ale,
how does the final circuit of your 45 SE look like. Did you apply the ultrapath connection Thomas recommended or do you run the amo in fixed bias mode?
Cheers
Peter
Old 26th January 2013, 10:12 AM   #142
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Hi Peter,
Wow, this is an old thread Anyway, I'm running my 45 in fixed bias: 34mA/300V. The driver is a gyrator in mu-follower output cap coupled to the 45. The current valve I'm using is the 7193. It sounds great.
I'm actually thinking of how the 45 could perform in A2 and whether is worth adding the complexity to the amplifier to get out about 3W from it.
Here are some early thoughts on that:
Driving the 45 DHT in A2 | Bartola Valves
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 26th January 2013, 05:52 PM   #143
45 is offline 45  Italy
45's Avatar
Originally Posted by mogliaa View Post
Hi Peter,
Ale
This is quite a popular amp. Many people can tell you it works fine!
TubelabSE
Building a 45 SET livingdeliberately Tubes / Valves 19 2nd August 2010 06:25 AM
Simple 5842-45 SET Amp Design Idea eeyore Tubes / Valves 41 10th March 2009 11:48 PM
WTB: SET 45 tube amp tnc Swap Meet 5 13th February 2009 10:32 PM
back after a long time amo Multi-Way 2 1st May 2008 12:56 AM
What 45 SET amp should I build? raver Tubes / Valves 3 30th January 2005 03:38 PM
Copyright 1999-2017 diyAudio
