To ground or not to ground the OPT secondary, that is the question - Page 3 - diyAudio
Old 7th May 2011, 03:04 AM   #21
cerrem is offline cerrem  United States
cerrem's Avatar
Originally Posted by Rodeodave View Post
The McIntosh MC75's OT has the following secondary connections: COM-4-8-16 and a separate winding for the feedback which has one end of the winding internally grounded. There is the option to install/remove a link to ground/float the secondary. Using the link the COM-tap is grounded.
Now iff it works, grounding the 4Ohm tap and using the com/8Ohm would seem like a nice idea. But does it really work that way? Do you get a balanced signal between com and 8Ohm them? What about the 16Ohm tap? Will it really be symmetric to 4OHM=GND? What happens to the primary impedance, does it see what's going on on the secondary in this case?
Keep in mind that the MC outputs are really wound COM-4-9-16...even though they are labeled for 8 ohms...
Chris
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 09:42 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
How do you properly ground a Tamura OPT? arnoldc Tubes / Valves 2 15th July 2004 12:43 AM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 01:08 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright 1999-2017 diyAudio
