Toroidal Transformer Cover - Page 2 - diyAudio
Old 14th April 2012, 10:51 PM   #11
Fenris is offline Fenris  United States
A local kitchen supply store will probably have various sized stainless bowls that could be of use.
Listen to the music through the stereo, not the stereo through the music.
Old 15th April 2012, 07:52 AM   #12
Shoog's Avatar
I used a pair of aluminum milk pans with the handles cut off.
Shoog
Old 15th April 2012, 04:09 PM   #13
How do you secure the transformer inside? Then how do you mount the whole thing on the chassis?
Old 15th April 2012, 06:13 PM   #14
Shoog's Avatar
Mount them with the standard mounting apparatus and then epoxy the pans over the top. Make certain to roughen the mating surfaces before applying the epoxy.
Shoog
Old 15th April 2012, 06:18 PM   #15
I found some fan ducting that was useful, but can't find the reference in B&Q any more. I'm in UK.
Greenwood solid ducting, B&Q, 10.5cm internal, for fans NDX100, NTX100
Marley, Maidstone. 01622 852585
Andy
Old 16th April 2012, 06:53 AM   #16
Here is what I did.
For fixing the vessel, I put 3 holes on the bottom near the perimeter and put nut-bolts to the chassis bottom. The torroid being curved at the outside has gap at the bottom.
I just placed it in the container and put some support with heat tolerant materials.
For fixing the cover, I had these straight ss plates with two threaded holes that were used to support transistors onto the heatsink. Just put one hole on the vessel and another on the lid.
Gajanan Phadte
Old 16th April 2012, 01:41 PM   #17
dhtrob is offline dhtrob  Netherlands
dhtrob's Avatar
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Rob
Alpair-10: to cover or not to cover, that is the question markaudio Full Range 13 1st March 2010 08:07 PM
Toroid transformer cover? Evenharmonics Tubes / Valves 21 2nd August 2009 11:07 PM
Toroidal transformer Ghianni Power Supplies 8 15th November 2006 04:44 PM
Transformer Cover FrankRoss Parts 3 7th December 2004 06:49 AM
Transformer Cover TunaFish Tubes / Valves 3 16th March 2004 06:28 AM
Copyright 1999-2017 diyAudio
