diyAudio Sponsor
Old 8th November 2010, 05:20 AM   #1
eeyore is offline eeyore  Australia
Default 5670 Thoughts?
What do you guys think of the 5670 as a gain tube in a preamp stage application. This will be coupled to a 6n6/5687/etc hefty tube to do the lifting. Looking for a medium mu dual triode. Discounted the 12AU7, 12SN7.
DF
http://diy-audio-blog.blogspot.com
Old 8th November 2010, 09:25 AM   #2
Miles Prower's Avatar
No direct experience with this one, but it looks like you ought to be able to find a decent loadline if you have the Vpp margin to get the plate current above 5.0mA or so. Looks like a good choice if you need something that falls between a 12AU7 and a 12AT7 for gain.
Maybe someone has actually tried them?
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 8th November 2010, 01:04 PM   #3
tubelab.com's Avatar
I have used them in LTP. They work good. Odd pinout though. I have seen schematics using them in amplifiers and preamps but I don't have anything in memory right now. Search here or Google using all of the possible numbers.
5670 = 2C51 = WE396A
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 8th November 2010, 02:27 PM   #4
Hello,
The 5670 is a nice little tube. I have assembled several breadboard circuits with it. Take a look at the curves; they look well behaved; straight and evenly spaced. There are many of them around for not much money. They were built to be used in a M1 tank.
DT
All just for Fun!
Old 8th November 2010, 02:30 PM   #5
Svein_B is offline Svein_B  Norway
The Russian and Chinese 6N3 are also equvalent. Used in many amps and CD plyaers sold on Ebay.
Old 8th November 2010, 05:31 PM   #6
kevinkr's Avatar
Originally Posted by DualTriode View Post
Hello,
DT
All just for Fun!
It's pretty popular in this neck of the woods for line and phono stages, reputedly a good sounding tube. I have a number here and a line stage that uses them that I never finished.. (Someday?)
www.kta-hifi.net
Old 8th November 2010, 05:52 PM   #7
Default 5670 Tube
The 5670 triode is used in S5 electronics K-16LS amp kits, among others, as a phase splitter, and in their add-on 'preamp' and tone circuits. I have built a few of these kits and never had a reliability issue with the 5670 or for that matter the 6005 pentodes used in the power amp section. Cost for a 5670 is $6.00.
Old 8th November 2010, 06:58 PM   #8
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Here you have one: Reference preamp Othello !
2C51 = 5670 as you probably know
Old 8th November 2010, 07:20 PM   #9
el156 is offline el156  Portugal
el156's Avatar
I Like very much the ECC804 as dual triode medium mu ! Have done some things with them and are very good ! Dont know if someone tested this ones but are very linear and i like the sound !
Old 8th November 2010, 07:49 PM   #10
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Do you mean 5670 is similar garbage?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Diy Line Amp 5670 xiangyi Tubes / Valves 3 7th September 2010 01:49 AM
5670 harwoodspark Tubes / Valves 35 13th March 2010 08:26 AM
5670 SRPP DC coupled to 6S4A alexg Tubes / Valves 7 5th June 2008 12:30 AM
FS: Matched pair NOS RCA 5670 cartman Swap Meet 2 10th December 2007 08:12 AM
Page generated in 0.10322 seconds (84.80% PHP - 15.20% MySQL) with 10 queries
