| diyAudio Sponsor | ||
Hey guys I'm trouble shooting a guitar amp conversion.
I want to replace the .047 600V coupling cap(s) that go into my 12AU7 phaze inverter. I have 3 .2 caps I can series wire to give me the required 600V rating. It works out to a .06 600V cap. Do you see anything wrong with that? The leaky cap is on the left, the new ones on the right. I have a thread in the musical instruments section. http://www.diyaudio.com/forums/music...mp-thread.html |
#2 |
I think you would be closer with 4 in series, yielding .05uf and 800V with proper dropping R's across each cap.
You'll need to put balancing resistors across each cap so that they will equally share the voltage. 220K or so is typical. You need the resistors because the resistance of each cap can vary, and they will not share the voltage evenly.....one can easily exceed it's 200V rating without the R's. Last edited by boywonder; 7th November 2010 at 05:47 PM. |
#3 | |
It would be better still to try to obtain a coupling capacitor with the 600V rating. AuriCaps come in 0.47uF / 600V (or very close to it). |
#4 |
Ok sounds good.
I did try it real quick, it did "work" and cleaned up the sound a little. I do have some other older caps that may be working. Just playing around to see what I need. Making a list for new caps, but as this is a conversion project I got to fiqure out all my changes first. Thanks guys. |
#5 |
#6 |
The trio looks like "brown turds" like Fender used in the later 60s / early 70s. They have a bad rap but all of mine test strong and do not leak dc.
I'm all for improvising when needed but I would not do that. To scary for me. |
#7 |
Ok I removed them.
Is there a slim chance the 600V is not required for the phaze inverter? I also have some .04 pancake style coupling caps (everywhere in the signal path) I would like to replace, however I don't know what voltage they are. Any suggestions? |
#8 |
Fair chance the PI's voltages are below 400.
400v and 630v versions: 150473J400DB Mallory Polyester Film Capacitors 150473J630EC Mallory Polyester Film Capacitors May as well go 630v. |
#9 |
Ok, well I managed to scrounge up a pair of Sangamo .1 600V.
Seems to be ok, sounds great. I wonder if I should get .1 rather then the .047 that was in there. What do you think? |
| Capacitors in series for coupling? | bst | Tubes / Valves | 11 | 18th March 2010 05:43 PM |
| Polar electro with bypass cap to replace nonpolar as coupling cap? | at77 | Parts | 0 | 12th January 2010 02:05 AM |
| can I use an electrolytic cap as coupling? | Nordic | Chip Amps | 2 | 20th September 2005 09:12 PM |
| Coupling cap | Raka | Chip Amps | 11 | 9th June 2003 01:06 PM |
| .22uf cap in place of .25uf coupling cap, OK? | bbaker6212 | Tubes / Valves | 5 | 15th July 2002 09:08 PM |
| Page generated in 0.09913 seconds (79.08% PHP - 20.92% MySQL) with 11 queries |
