diyAudio Sponsor
Old 13th July 2003, 09:28 PM   #1
Default Conrad Johnson PV-7 noise
Hi all, I did a little research on this and couldn't find a satisfactory answer:
I have noise on my CJ PV-7 tube preamp that is well beyond what it should be, and much more than it used to be (it's volume is independent of the volume pot.) It is a hiss/crackle not a hum. Changing out every tube makes no difference. I e-mailed the CJ repair department a long time ago (long standing problem that I am getting around to fixing) and they suggested if switching out tubes makes no difference, it is probably a bad power transformer.
Is there any possibility that it might be something else? I'd like to know before I go off and replace the power transformer.
Old 14th July 2003, 10:35 AM   #2
Could be a bad ("cold") solder joint finally making its presence heard. Try wiggling resistors?capacitors on the circuit board (gently!) to see if one of them is loose.
Old 14th July 2003, 02:39 PM   #3
diyAudio Senior Member
fdegrove's Avatar
It could be a number of things, a zener diode, a HT regulator, a cap, flaky resistor etc.
The last thing I'd suspect would be the powerxformer.
Frank
Old 14th July 2003, 03:01 PM   #4
SY's Avatar
See what the B+ rail and filament voltages are (if you don't know your way around high voltage gear, don't listen to me! Serious safety issue! ). If they're in the normal range, your power transformer is OK.
Could they have said "power transistor"? The ones in the regulator could certainly cause a problem like this.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th July 2003, 04:01 PM   #5
analog_sa's Avatar
It may even be a bad tube socket.
Old 28th July 2003, 03:22 AM   #6
Thanks for the ideas everyone. I contacted the CJ repair department and they suggested it might be a capacitor in the power supply. I tested every one of the supply caps and they looked ok (high dc resistance and proper capacitance). I guess it's on to other components (diodes maybe?)
Old 28th July 2003, 07:36 AM   #7
analog_sa's Avatar
This surely can't be so difficult. CJ preamps are very simple. I don't have a circuit for PV7 but looking at PV6 it should be easy to narrow the culprit down. Why do you think it's the PS? Is the noise equal in both channels? It should be possible to remove all tubes bar the output cathode follower. Is the noise still there?
Have you checked the bypassing cap on the zener array? Have you cleaned all tube sockets?
cheers
peter
Old 29th July 2003, 03:24 AM   #8
The pv7 schematic is now posted on my webspace for your reference here. It's a little hard to read, but far better than not having it.
The cap that I think you mean by the bypassing capacitor on the zener array (c4 on the diagram) was one of the ones I checked, it was fine.
I took out all the tubes except for V5 which appears to be the output tube. (V1-3 are just the phono stage which I don't use anyway) The noise was present and a bit louder than with all tubes in, and somewhat more pronounced in the left channel. With V4 and V5 both in, the noise is a little lower, and basically balanced between channels.
I haven't cleaned the tube sockets, I suppose given that the noise was there even with only V5 in, if it is a socket it has to be that one, but I am too pessimistic to think that it is that simple. Any tips on cleaning sockets?
Old 29th July 2003, 10:48 AM   #9
fdegrove's Avatar
Just pulling the tube out and reinserting it a few times should have sufficient cleaning effect already.
BTW, don't use the preamp without all the tubes in place for that will reduce the load on the PSU making the B+ rise to probably unsafe values for the surroundig components.
Frank
Old 29th July 2003, 01:29 PM   #10
analog_sa's Avatar
Ehm, don't think so Frank, B+ is regulated...
Question Conrad Johnson reg. psu? KJ2005 Tubes / Valves 9 18th November 2008 07:25 PM
FS: Conrad Johnson Premier 11A amp Studley Swap Meet 0 18th January 2007 10:50 PM
Conrad-Johnson PV6 Preamp paulcurrie Tubes / Valves 3 17th April 2004 07:11 PM
Conrad Johnson Premier 10 Freddie Tubes / Valves 1 2nd July 2003 09:17 AM
conrad johnson help efoda Tubes / Valves 3 24th January 2002 03:23 AM
Page generated in 0.09864 seconds (84.17% PHP - 15.83% MySQL) with 10 queries
