Buzzing, could it be a ground loop?
Old 13th July 2003, 08:07 PM   #1
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Default Buzzing, could it be a ground loop?
I have a tube preamp, all worked fine until I switched the output capacitor (same value, just a higher voltage part) then when I pluged it back in I get a very loud buzzing sound. When not connected to an amp it measured 0.5V 60Hz coming out of the preamp output with volume turned to the min.
Could this be a ground loop? I ask because the voltage seems high and the buzzing gets amplified in any later stages, it seems to me ground loops would only occur when the preamp was connected to something else and it wouldn't get amplified... right? Well, just looking for advice I can't figure out what happened here.
BTW the preamp is wired up with a star ground and hum wasn't a problem before...
Old 13th July 2003, 09:32 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Not likely.
What may have happened is the you somehow lost a ground connection when you replaced that output cap.
Have you checked for cold soldering joints?
Frank
Old 13th July 2003, 10:05 PM   #3
JoeBob's Avatar
Well, thanks for heading me in a direction, let's hope it's the right direction. I haven't checked everywhere for cold joints, because of the star ground that's going to be alot of checking.
But if that's a possible reason it would make sense, maybe I bumped something when changing the cap, for I am pretty darn certain that cap didn't change anything.
I'll hunt for a ground conection that got loose.
Old 14th July 2003, 03:24 AM   #4
JoeBob's Avatar
Hmmm... all of the ground points in the circuit have good contacts and all measure a resistance of 0 to ground, so I guess no ground points got loose.
After looking further I notice that there is also a 1kHz signal present as well, could this be oscilation? And if so, what are common reasons for this (that could explain it spontaneously happening)?
BTW I'm using a 6922 as a common cathode stage followed by a 6AS7G as a cathode follower.
Buzzing, could it be a ground loop?Hide this!Advertise here!
ground loop Jamh Chip Amps 10 2nd November 2007 08:18 PM
Fix a ground loop! sorenj07 Digital Source 2 1st October 2007 07:39 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 07:46 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 01:55 PM
Ground loop hum jag Pass Labs 20 25th November 2002 06:32 PM
Copyright ©1999-2017 diyAudio
