| diyAudio Sponsor | ||
What advantages would cooling of tubes have?
My first thought is about noise, Would it cause less noise? How can I cool down the tubes? I have thought about drilling some holes in the chassie near the tubesockets and use some fans, this is probably the simplest method. Other thoughts is about using some kind of heatspreaders at the tubes, maybe they can then also functions as shields. A more advanced method would be to use some kind of liquid, this liquid has to be circulated through some pipes which are coupled to the tubes. I have heard very little about cooling of tubes, in fact the only thing I have heard was about a mic amp for pro use who used some kind of liquid cooling. |
#2 |
diyAudio Senior Member
TUBE COOLERS. Several industrial tubes use cooling in various forms such as forced aircooling, oil cooling etc. EIMAC. Cheers,
Frank |
#3 |
Cooling a valve reduces noise. A Sony microphone used Peltier effect cooling. The problem is that the glass envelope isn't very round or consistent unless specially specified, making it difficult to obtain good thermal contact. One way around the problem would be to suspend the valve upside down in a finned bath of oil.
Fans are noisy. Even the quiet ones. Nevertheless, pointing a fan at a valve cools it quite effectively.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 |
Thanks.. very interesting...
I didn't mention that I'm aware of that transmitting tubes usually use some kind of cooling, mostly forced air or water circulation. |
#5 |
The biggest ones use steam.
#6 |
steam?
How can steam be used for cooling? |
#7 |
I thought that would surprise you! It takes six times the energy to convert water at 100C to steam at 100C as it takes to heat the same mass from 20C to 100C.
#8 |
It's called phase transition cooling, or something like that.. obviously you can't use hard water
A lot of big tubes are spec'd for water and forced air cooling: water for the anode, air to keep the pin seals cool (e.g. heater). Tim (has a 4X150A and a pair of 4CX250R)
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#9 |
If you are designing from scratch, choose tubes that don't run too hot, ie 6V6 instead of EL84, 6550 instead of EL34 etc. The bigger the glass envelope the more surface area and better cooling, i guess.
Most tubes seem to run fine in free air unless you have a high ambient temperature. Norway is about the same as NZ so you are ok As for reduced noise, have you heard how loud computer fans are? They suck, I think any decent music system should be fanless. But good ventilation is a great idea, I try and recess my tubes into the chassis a little to get airflow around them, the so called "chimney effect". Keeps them cooler. |
#10 | |
Bill has an article on them. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| DIY vacuum tubes! | sss | Tubes / Valves | 1 | 17th January 2008 01:49 AM |
| Repair vacuum tubes? | Nixie | Parts | 9 | 8th March 2007 11:03 PM |
| vacuum tubes | smak | Swap Meet | 2 | 25th January 2006 06:44 PM |
| NOS Vacuum Tubes for Sale! | mrdon | Swap Meet | 1 | 11th August 2005 07:45 AM |
| Page generated in 0.13224 seconds (63.81% PHP - 36.19% MySQL) with 10 queries |
