diyAudio Sponsor
Old 14th July 2003, 11:23 PM   #11
PRR is offline PRR  United States
PRR's Avatar
> What advantages would cooling of tubes have? Would it cause less noise?
If you could cool the cathode enough to reduce noise a measurable amount, it would just stop working at all. The cathode MUST be hot to make those clingy little electrons jump off where the plate and grid can affect them. And emission is like 3rd-power of cathode temperature, while noise changes very slowly.
If you are over-heating the plate, cooling will increase life. However small glass tubes don't have enough thermal contact between the plate and any part you can put a cooler onto. Some huge (kilowatt) transmitter tubes do have provisions for cooling the plate directly. But don't over-do it: the transmitter tubes are designed to run hot and won't getter well if you manage to cool them too much.
If you work the tubes very hot and turn them off and on many times a day, the seals may crack. Cooling around the pins is usually something to check if your tubes go gassy quickly.
> drilling some holes in the chassis near the tubesockets and use some fans
Do as much of that as you like. It will keep the resistors and other parts on the socket from cooking and drifting over time.
Old 14th July 2003, 11:57 PM   #12
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Interesting post, PRR, and I agree with most of your points.
However, (you knew this was coming), noise is only signficant with small-signal valves, and it doesn't solely come from the shot noise of electron emission. There are also some distinctly dodgy insulators with considerable voltage across them that are connected to a high-impedance input (the control grid). The micas.
The anode cools by radiation, but some of this is absorbed by the envelope, raising its temperature, and simultaneously reducing the temperature differential between the anode and envelope, which reduces anode cooling. The micas are in close thermal contact with the anode, and insulators become leakier as temperature rises. Alternatively, it could be that hot micas begin to release water vapour, causing grid ion current.
I accidentally proved the noise theory by fitting snug-fitting screening cans made of 22mm copper pipe with a slot in the side to B9A valves. After half an hour, there was a lot of LF noise, and the valves were hot. I removed the cans, and the noise subsided. The cans, being relatively shiny, had prevented radiation.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 15th July 2003, 12:31 AM   #13
diyAudio Senior Member
fdegrove's Avatar
So do I... but there's more to tube coolers than that; lowered microphony is one thing.
If we'd want to extend tube life regardless of top performance we could just as well lower cathode emission by reducing heater voltage/current.
Cathode emission is not going to be affected by a cooling element on the glass envelope, so I seriously doubt that in this application it's going to affect this in any negative way.
Yep....I found the best screening cans to be matte in colour, i.e. none reflective.
There's a lot more that can be said about this, we're entering muddy waters here.
Frank
Old 15th July 2003, 08:23 AM   #14
Gunders is offline Gunders  Norway
Originally posted by ShiFtY
As for reduced noise, have you heard how loud computer fans are? They suck, I think any decent music system should be fanless.
Yes, for Hifi equipment the noise from the fans will be annoying. But what about guitaramps?
Well the noise from the fans would probably still be annoying when you're playing at low levels, but in many(or maybe most) situations guitarists would like to play rather loud.
Old 15th July 2003, 09:32 AM   #15
Well, I don't know if guitarist care much about noise(tube noise) in their amps when they are playing loud, but cooling could probably extend the life of the tubes.
I have searched a bit for some low-noise fans, and I found a couple which have a noise of 12 dBA, thats substantially lower than the noise produced by computer fans.
Old 15th July 2003, 03:26 PM   #16
jevta is offline jevta  Serbia
Default cooling of vacuum tubes
First, you have to know reason for cooler. Amps with baby tube EL 84,EL34 , EL 88, don't need cooler.Big tube like 6c33b need cooler for socket and area near .I made on my OTL 6C33B two cooler 12v 12 W with 25 db noise.For put down this noise very efecty put down voltage on minimum 6 V.
Old 15th July 2003, 10:10 PM   #17
fdegrove's Avatar
Talking KEEPING IT COOL...
Sure...nonetheless a reading of Bill Perkins papers is worthwhile...
There's more to a tubecooler than just temperature.
Ciao,
Frank
Old 17th July 2003, 10:01 PM   #18
Really? I dont care this fact. If that had rapid influence only on sound please tell me adress where I can learn about that.
Old 18th July 2003, 12:00 AM   #19
fdegrove's Avatar
Default LET'S KEEP IT COOL...
You'll find all the appropriate info in post #10 by Planet10.
Another good reason for using a wel designed tubecooler is that it reduces the effect of airborne and structure borne vibrations.
Frank
Old 18th July 2003, 01:12 AM   #20
frugal-phile(tm)
planet10's Avatar
Default Re: LET'S KEEP IT COOL...
Especially if used in conjunction with an iso-socket. Parts Connexion talked Bill into redesigning his isolation socket so that it plugs into the existing socket which means they can be installed without soldering (althou at the expense of another contact)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
DIY vacuum tubes! sss Tubes / Valves 1 17th January 2008 12:49 AM
Repair vacuum tubes? Nixie Parts 9 8th March 2007 10:03 PM
vacuum tubes smak Swap Meet 2 25th January 2006 05:44 PM
NOS Vacuum Tubes for Sale! mrdon Swap Meet 1 11th August 2005 06:45 AM
Page generated in 0.10940 seconds (83.81% PHP - 16.19% MySQL) with 10 queries
