Ground loop problems - looking for opinions - diyAudio
Old 13th July 2003, 08:39 AM   #1
Default Ground loop problems - looking for opinions
Hello everyone,
Just finished building this 6BM8 amp, sounds very nice when every channel is tested separatly, but when connected together one channel sounds 40% louder then the other and the lower one is distorted. I suspect the grounds to be the problem because when I disconnect the ground wire it is OK. I have builet separate power supplies but the ground is still connected via the tuner I am using. Decupling the ground solves the problem.
What I do not understand is why connecting the R and L grounds creates the problem and how can I solve it without using a transformer in the input.
http://www1.odn.ne.jp/~ces58160/tube...m8/6bm8pp.html
Thank you very much.
Glass_painter
Old 13th July 2003, 10:59 AM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
There's nothing in the circuit to diagram to suggest that there should be a problem, so I think you are looking for a wiring error. Check your DC voltages when you connect the grounds together.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 13th July 2003, 11:18 AM   #3
Default Ground loops?
Yes, this was my guess as well so I looked at the DC volages, they do change but very little and all values are in spec (connected or not). I even took the power supply apart and built a dubble PS separate for aech side, now the only mutual wire is ground.
Any other ideas?
Thanks.
Glass_painter
Old 13th July 2003, 11:22 AM   #4
EC8010's Avatar
If you have an oscilloscope, remove the NFB and apply a sinewave from an oscillator or test CD to both channels and look to see if it's the input stage or just the output stage that is distorting/changing level.
Old 13th July 2003, 12:16 PM   #5
Thanks, I will try it tonight and let you know.
Glass_painter
ground loop Jamh Chip Amps 10 2nd November 2007 08:18 PM
Fix a ground loop! sorenj07 Digital Source 2 1st October 2007 07:39 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 07:46 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 01:55 PM
Ground loop hum jag Pass Labs 20 25th November 2002 06:32 PM
Copyright 1999-2017 diyAudio
