diyAudio Sponsor
Old 1st November 2010, 11:36 AM   #1
Brit01 is offline Brit01  United Kingdom
Default Fixed bias failure B+ switch off protection
Looking for a simple circuit that will switch off the B+ if the fixed bias fails or falls too low.
Planning to put the relay on the primary of the B+ tranny.
If the fixed bias falls too low then it triggers the relay.
In theory will this work?
Any suggestions/opiniones/experiences?
File Type: jpg FIXED BIAS B+ SWITCH OFF PROTECTION.JPG (30.4 KB, 143 views)
Old 1st November 2010, 04:03 PM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
The NPN will always be off as it's base voltage is lower than its emitter voltage. So no, the circuit will not work.
Another issue is that the base current is not limited. You'll need a resistor between the base of the NPN and the bias voltage.
To make this circuit work, I suggest changing the NPN to a PNP and "hanging" the circuit from the ground rail. The bias voltage pulls the base of the PNP low, thereby turning it on. If the bias voltage isn't low enough, the PNP will turn off.
You'll have issues at start-up, though as the bias voltage will be out of spec at that time.
Old 1st November 2010, 04:12 PM   #3
kevinkr's Avatar
The transistor symbols are incorrectly drawn, and in fact the base of the 2N3906 (PNP!) needs a resistive voltage divider ahead which is not shown here.
I used a very similar in fact almost identical circuit to protect against bias failure in one of my designs, and not everyone was able to get it to work reliably. (Start by changing the direction of the emitter arrows and you'll be heading in the right direction.)
In terms of B+, it will not be applied if bias is not present, and usually the bias supply should be arranged to come up to full voltage long before B+ is present.
Simulating a circuit in LTSpice should allow you to come up with a design that actually works. There are lots of ways to do this. You might even consider an LM311 comparator or similar. (watch input common range!)
www.kta-hifi.net
Old 1st November 2010, 05:05 PM   #4
Yes you're right. The arrows were incorrect. My error.
Let me look into this further in the evening.
Thanks for the responses guys.
Old 1st November 2010, 05:28 PM   #5
I placed a divider here (1K/10K), re-designed the pnp/npn arrows and it seems to work in the simple simulation. Relay cuts in anything below -12 volts.
I can always set up a simple proto on a breadboard.
I'll look into this. Is there a freeware copy available?
Old 1st November 2010, 05:31 PM   #6
kevinkr's Avatar
<snip>
LTSpice is gloriously free, extremely powerful, and easy to get here: Linear Technology - LTspice IV Downloads and Updates
Runs in Windows and Linux (under Wine)
www.kta-hifi.net
Old 2nd November 2010, 12:34 AM   #7
SpreadSpectrum's Avatar
I have taken the approach of sampling cathode current and feeding that to a comparator. This will save the tubes in the case of a bias supply failure and save the output transformer in the case of a tube short. Two birds, one stone.
Old 2nd November 2010, 10:19 AM   #8
Would this work in a circlotron design? Do you have more details?
Fixed bias vs. auto bias HFGuy Tubes / Valves 30 14th October 2011 09:45 AM
Finding bias point in PP fixed bias beamnet Tubes / Valves 14 7th December 2008 01:25 PM
Battery grid bias to fixed bias in Toccato? w00t Tubes / Valves 3 2nd December 2007 12:34 AM
Self Bias and Fixed Bias for Big Tubes? commstech Tubes / Valves 12 24th November 2006 02:17 PM
Failure with easy spk protection circuit bigpanda Solid State 20 19th August 2004 04:24 AM
Page generated in 0.09204 seconds (83.50% PHP - 16.50% MySQL) with 11 queries
