| diyAudio Sponsor | ||
I have a´ pair of Sentec M30 mono amplifiers constructed for running two EL-34 type tubes in p-p. Can I put in 6p3s-e in place of EL-34 without to much risk ? The OPT:s primary impedans is 6kOhm when your speaker have 8 Ohm. The Anode voltage is about 400V. Thank you ! |
#2 |
google it there are many questions about this, the pinout is almost the same except for the non connected pins, so you needs to watch the oringinal builder didnt use the non internally connected pins for any connection (which people often do).
#3 |
работник
Compared to modern production EL34s, I'd say that the 6П3С-Е (6P3S-E, the coin-base version) is tougher and more reliable. Don't use the ordinary 6П3С though, that's a 6L6GB analogue, and only rated for 270V on the screens, 19W anode dissipation.
The bias voltage is very different though, and you will have to correct this before installing a 6П3С-Е. Measure the cathode current using those resistors in the cathode leads, then look up the bias voltage needed against the screen voltage the amp is running. Watch out though, the sample-to-sample variation on these is very wide, and your amp specifies matched pairs! Many NOS 6П3С-Е are gassy, and you need to test for this, and monitor the tubes' cathode current for a hour or more before you're sure it's stable. A slow roast at 100 deg C for 12 hours will often fix the gas. The 6П3С-Е will work in a EL34 socket with no connexion changes. |
#4 |
#5 | |
Any idea on which cathode current that should be the "optimal" setting whit 6P3S-E ? EL-34 needs about 52mA "optimal" as you can see in the drawing. Thank´s again ! |
#6 |
работник
52mA with 400V is a shade over 20W.
6П3С-Е will withstand 20W better than a modern EL34 can. Why not start there, at 50mA? then you can compare the sound. If you modify your bias circuit so that it can adjust between -45V to -35V, approximately, it will be OK. start at -45V and adjust until the current is correct (1.0V at the test point). You have two adjusters, so a matched pair is not too important, despite the schematic note. |
#7 |
Try 6П27С instead of EL34. It is better than 6П3С.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#8 |
работник
#9 |
Unfortunately I don't have them...
#10 |
Neither do I, but I do have some 6P3S-E:s . . .
| EL-34 and 100k pot | podboy | Tubes / Valves | 1 | 26th June 2007 11:49 PM |
| Single Ended EL-34? | jaymanaa | Tubes / Valves | 11 | 28th March 2006 10:32 PM |
| Siemens EL 34--i have 8 for sell | RogerWilco | Swap Meet | 0 | 4th September 2005 09:32 PM |
| Power Amplifier With EL 34 | marinbnm | Tubes / Valves | 4 | 3rd November 2004 02:39 PM |
| el-34 suggestion | mezon | Tubes / Valves | 7 | 10th April 2003 09:28 PM |
| Page generated in 0.10540 seconds (80.59% PHP - 19.41% MySQL) with 11 queries |
