replacing diodes in my tubed-cd player
Old 12th July 2003, 01:11 PM   #1
jarthel is offline jarthel  Australia
Default replacing diodes in my tubed-cd player
Well the tube uses 6DJ8 family and it uses a bridged rectifier that's rated at 8A 400V. Is there any chance than a 6DJ8 circuit to consume such amperage?
I want to replace the bridged rectifier with 4A 1000V ultrafast diodes (fashioned into a bridged rectifier).
Thanks for the replies.
Jayel
ps. I'm not sure if this belongs to the proper section so I apolgize if advance.
Old 12th July 2003, 01:24 PM   #2
On Hiatus
SY's Avatar
For continuous curent, the 4A will do fine. The question I have is what follws them? If there's a big cap bank, the surge (peak) current rating may be an issue.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th July 2003, 01:34 PM   #3
there are 5 220uF 250V caps which I assume is for this bridged rectifier in question. And there's a 10000uF 25V which I assume is for another supply that uses a positive voltage regulator possibly for the heaters.
Old 12th July 2003, 03:03 PM   #4
On Hiatus
SY's Avatar
Well, assuming the rectifiers in question aren't being used for the filaments (trace it out to be sure), 4A doesn't seem unreasonable.
replacing diodes in my tubed-cd playerHide this!Advertise here!
Tubed IR spectrophotometer 7n7is Equipment & Tools 17 21st November 2009 04:23 PM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
worth replacing the pcm56p-k in an old cd player? badbrother Digital Source 3 8th September 2007 08:17 AM
Tubed HU EvilGenius Car Audio 5 26th May 2006 09:54 PM
FS: R-core transformers, audio caps, diodes, DVD player, etc pkpickard Swap Meet 5 8th September 2004 03:22 AM
