| diyAudio Sponsor | ||
just a fast question about what to expect (visually) from an 83 rectifier
i found this pic googling around, now i'm building an aikido using the 83, but the blue glow is barely visible with lights off, and nothing anywhere near the below pic.. is just me that i'm expecting too much or it is right this way? |
#2 |
Sadly, life is not as glamourous as art. Or get a better camera/ use a tripod
#3 |
Hey Guys, take a look at the magnificent glow of the rectifiers in this monumental 1955 vintage Philips 1000 watt amp playing Bach.
YouTube - Bach Toccta D-Moll on 1000W Audio Tube Amplifier EL6471
A stiff power supply in a great-sounding amp is always better for you than a stiff drink.
#4 |
With a good camera, tubes often come out prettier in dark shots than they actually look in real life.
#5 |
imfree,
that ROCKS!!! ./e |
#6 |
Ahh, mercury vapor rectifiers. I remember them from RCA TV transmitters. How much they glow is dependant on the current flow thru them. If they ever start turning green, its time to change them out or you will be off the air.
#7 |
And I remember Mercury Vapor rectifiers in AM transmitters too. You could watch the modulation in the brightness of the glow.
Just make sure the filaments are hot enough before you apply the high voltage!
Frank |
#8 | |
yes but.. i thought that preheating of the filaments was necessary just before turning on after long and probably side storage |
#9 |
If the tube has been stored on it's side (even briefly), let the filament warm up for a minimum of 45 minutes before applying high voltage to the anode.
Otherwise, the arcback can be pretty dramatic and destructive.
Frank |
#10 |
Thanks for the kind words, 77seriesIII. The video clearly and dramatically showed what would have required me to compose a lengthy text on the subject of current-modulated glow in rectifier tubes. One can't beat the visual effect of Bach's toccata on those rectifiers!
| Mercury vapour rectifier for George | aardvarkash10 | Tubes / Valves | 4 | 22nd November 2009 01:25 PM |
| mercury rectifier for electrostatic bias | oublie | Tubes / Valves | 8 | 14th July 2009 10:51 PM |
| delay on for 83 mercury vapor | ecir38 | Tubes / Valves | 1 | 15th June 2008 11:18 PM |
| 83 rectifier peak repetitive current? | plovati | Tubes / Valves | 1 | 27th June 2007 09:01 PM |
| Looking for a 83 rectifier model | bembel | Tubes / Valves | 1 | 26th January 2007 11:27 PM |
| Page generated in 0.10227 seconds (76.55% PHP - 23.45% MySQL) with 11 queries |
