diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   So, im going to replace the Alps with a PEC...someone help? (http://www.diyaudio.com/forums/tubes-valves/176097-so-im-going-replace-alps-pec-someone-help.html)
ncdrawl 27th October 2010 12:43 AM
My tech is going to do it for me (on my Jolida 102B) . I just need to know what part number the PEC(well built, milspec) pot is...and where to get them of course.
thanks for any help.
Eli Duttman 27th October 2010 12:54 AM
You use a KKA series part of the value shown in Jolida's schematic. You buy the pot. from DigiKey.
dsavitsk 27th October 2010 01:24 AM
Just make sure you save the Alps to put back in when you discover that the PEC is unbalanced and noisy. Oh, and the PEC needs a different size mounting hole, so you are going to have to drill out the hole in the chassis.
ncdrawl 27th October 2010 02:39 AM
Originally Posted by dsavitsk (http://www.diyaudio.com/forums/showthread.php?p=2344922#post2344922)
ok, well, every ALPS blue ive had experience with has been trash, so can you tell me what pot to get that would work off the bat, that would be an upgrade from this ALPS?
It is between the GoldPoint, TKD, and PEC. I will *not* use any alps pot.
nic6paul 27th October 2010 02:44 AM
I have a goldpoint in one of my amplifiers. A real good quality part, I actually feel a bit guilty about spending that much money on it...have been thinking about selling it.
HollowState 27th October 2010 02:51 AM
1 Attachment(s)
What about something like this. They're available in various resistances.
10K 24 Step Ladder Type Stereo Volume Potentiometer - eBay (item 300485553189 end time Nov-04-10 09:48:09 PDT)
limono 27th October 2010 03:24 AM
What particular problem with Alps Pot did you have?
ncdrawl 27th October 2010 04:24 AM
Originally Posted by limono (http://www.diyaudio.com/forums/showthread.php?p=2345007#post2345007)
oh, it wasnt just this one, but 4 in all. the problem is that they get scratchy/noisy over time.
I have had the pot on the jolida replaced 2!! times, each time with ALPS blue(as per the factory).
I also have a custom built headphone amp that we originally used ALPS Blues on...again, noisy
i am quite frankly tired of dealing with it and want to buy something where I wont deal with this sort of thing.
dsavitsk 27th October 2010 04:35 AM
I've probably used 30 to 40 Alps blue pots over the years, and I've never had one develop a noise problem. I have had some that were not well matched at low volume, but that's about it. Do you live in a particularly harsh environment?
Pano 27th October 2010 04:40 AM
Ditto on the PEC. I used them but was not happy with them.
A stepped attenuator or a TKD are my choice now. Have had god luck with Noble, too.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
