So, im going to replace the Alps with a PEC...someone help? - Page 3 - diyAudio
Old 27th October 2010, 02:26 PM   #21
ncdrawl is offline ncdrawl  United States
Originally Posted by djn View Post
This is interesting. I've never heard of an Alps doing this....however, I have one that is scratchy. I thought I was the only one. Mine is an environmental issue though. I had this reciever in the garage for a year and the Alps got loaded up with gunk. If you want a really cool and CLEAN V-pot, you should look at the LightSpeed optical Vpot
thanks Sir! Link?
Old 27th October 2010, 03:36 PM   #22
Bigun is offline Bigun  Canada
Bigun's Avatar
The Poor Serbian Man's Optical Attenuator
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 27th October 2010, 03:54 PM   #23
Out of curiosity where did you buy your alps....eBay?
- Nic
Old 27th October 2010, 04:52 PM   #24
I can vouch for the fact that there are many fake ALPS out there. I have one of them. It was bought by my friend when it came with a substantial discount. They seem to be a bit noisy when cold but seem to improve as they warm up. Maybe I got lucky? The thing is about these fakes is that they look exactly like the real thing at first look. Then you notice that the finishing is not as good, the bushing size is a bit different (can't remember if bigger or smaller). The turning of it feels slightly different.
MY original ALPS are very good ( till I smoked it after shorting the supply V+ to ground through the wiper :-( Now I can feel a "step" as I turn it and get a crackling noise when I turn it. Must have burnt the track off.
Old 27th October 2010, 04:58 PM   #25
djn is online now djn  United States
djn's Avatar
Here is the link to the Lightspeed. On the page, is the guys link to his website.
http://diyaudioprojects.com/Solid/DI...ve-Attenuator/
Quikie22 has a very good point. There are many APLS knockoffs and they are junk. I only buy from Madison and PE so I know I am getting the real thing.
Old 27th October 2010, 06:28 PM   #26
Decker is offline Decker  United States
I've been using a PEC stereo potentiometer for about a year now in a Pass B-1 buffer. It does have a tiny bit of channel mismatch at low levels, but evens out as it is turned up. Overall it works very well. I have not had the urge to replace it.
B-1 assembly, Pass boards and PEC pots Russellc Pass Labs 27 30th March 2011 10:51 AM
TDK vs. Alps vs. PEC pots chuck55 Chip Amps 4 31st May 2009 07:05 PM
Source for PEC mono attenuators? Colescuttle Chip Amps 3 1st January 2007 11:04 PM
brown alps pot replacement?120k can i use 50 k to replace it homertooties Solid State 2 8th December 2006 06:12 PM
Hi, im new to DIY audio, im wanting to buy the audax HT kit and have a few questions undertoe Multi-Way 13 23rd January 2003 07:12 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
