diyAudio Sponsor
Old 26th October 2010, 07:24 AM   #1
nige838 is offline nige838  United States
Default DIY 50C5 mini amp...
Hello all,
Just wanted to share my newest project...
It's tubes are as follows:
35w4
12AT7
12AT7
50c5
It's built into a 6" x 4" x 1" enclosure, quite small...
Sounds amazing, very bluesy, even with a crap 1970s 8" that I dumpster dived for a few weeks ago...ever so slight of a hum, barely noticeable,
All tubes are pulled out of 2 1950s radios,
Total Cost: $35
Tell me what you think...
Old 26th October 2010, 08:10 AM   #2
aardvarkash10's Avatar
weally qute!
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 26th October 2010, 08:17 AM   #3
hidnplayr's Avatar
I think the capacitor on top will have a very short life..
Real tubes have top-caps
Old 28th October 2010, 07:33 PM   #4
Well, just to update...
I left it on for 12 hours to make sure that nothing melted and everything is A OK. I'm about to start working on another design that uses the popular 50L6GT and the 12AX7 (Although I may substitute 2 12AT6 instead)
Took it to the pawnshop and they gave me $100, not bad for a $35 investment...
Old 28th October 2010, 07:45 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I think you should rotate the output transformer so magnetic fields of power and output transformers would be perpendicular, it minimizes hum.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 28th October 2010, 08:18 PM   #6
and add a fuse...
Old 28th October 2010, 08:18 PM   #7
And ground the chassis...
Old 28th October 2010, 09:55 PM   #8
Yes, I know that I need to add a fuse, maybe 1 Amp? The chassis is grounded to the negative lead of the capacitor, and all the other grounds ground there too...
It doesn't have a bad hum at all, but next time I will run the output transformer perpendicular.
This is my first amp, so any feedback will be more than welcome. One thing that I didn't count on was the heat generated by these tubes. Now I understand why you can't just pack all of them onto a small chassis. Live and learn I guess.
Old 28th October 2010, 09:58 PM   #9
Also, should I ground the center tap from the AC in? I used the transfo. backwards to get the dual primaries to run the heaters and the other to run the B+ and B++.
Old 28th October 2010, 09:58 PM   #10
Wavebourn's Avatar
Wow, congratulations!
Quite good job for the first amp!
High Efficiency Mini DIY Speakers for T-amp DreadPirate Multi-Way 7 6th February 2009 01:48 AM
Small 50C5 Amp improvements targeteye Tubes / Valves 7 4th August 2008 04:46 AM
isolation transformer for 50C5 amp PRNDL Tubes / Valves 7 12th March 2007 04:43 AM
50C5 add-on amp tubbytwo Tubes / Valves 7 25th November 2004 08:01 AM
Page generated in 0.09531 seconds (80.89% PHP - 19.11% MySQL) with 11 queries
