| diyAudio Sponsor | ||
I have just received my first chokes ever. I have seen schematics that show polarity of chokes, but the Hammonds I just got don't show any polarity.
Joe |
#2 |
typically a choke will not have any polarity
#3 | |
diyAudio Senior Member
It may be directive though...not that I'd worry much about that.
Frank |
#4 |
Actually, I have a couple of chokes that are marked to delineate the rectifier end. I assume that this is because the insulation to chassis is better at this end than the other (this would be significant in a choke input supply).
Otherwise, there isn't any "polarity" in chokes.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#5 |
A choke might have a polarity so that the magnetic flux lines are in a certain direction relative to the chassis or some wires nearby.
Also, the core might possibly be designed to react a certain way to the movement of flux in one direction or the other. Generally, I'd imagine that if the choke itself has no polarization marks, it isn't intended to have polarization and thus should be used how the builder likes.
-- Duo, W1ngs, VA7MON, and lesser known handles. -- -- http://www.w1ngselectronics.com -- My Work and Projects -- |
#6 |
I'd imagine 1) capacitance from end of winding closest to core to the core itself, which is usually chassis-grounded; 2) insulation as EC8010 says; 3) flux orientation is a possibility, though generally a stray field from anything is considered detrimental, but whatever.
Polarity only really applies in transformers or tapped chokes which act as such (autotransformers). Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#7 |
Thanks for the response. I couldn't quite remember so I thought I would ask those in the know.
Joe |
#8 |
How about SE output transformers? Does the same apply?
#9 |
I suppose so, but the more important thing there would be getting the polarity of the audio signal correct and avoiding having one stereo channel out of phase with the other.
#10 |
Chokes that are intended for audio signal usage do have a right way and wrong way to connect them. When used as a plate choke you want the "start" (closest to the core) end of the winding to be at the lowest AC potential, usually an AC ground. The "stop" end of the winding should be connected to the plate of the tube.
The same thing applies to SE transformers. Gary |
| choke or inductor polarity | milen007 | Parts | 1 | 1st December 2008 01:54 AM |
| Choke rating for choke input duty | cbutterworth | Tubes / Valves | 14 | 9th November 2007 04:43 PM |
| Swinging choke vs std. choke in PS | Curly Woods | Tubes / Valves | 2 | 5th March 2007 08:30 PM |
| Swinging Choke or Smoothing Choke | danFrank | Tubes / Valves | 4 | 11th February 2007 11:05 AM |
| GE 97F cap polarity ??? | maynardg | Tubes / Valves | 0 | 3rd February 2007 09:20 PM |
| Page generated in 0.11839 seconds (64.78% PHP - 35.22% MySQL) with 11 queries |
