Have anyone built this 6V6 amp?
Old 25th October 2010, 08:32 PM   #21
athos56 is offline athos56  United States
athos56's Avatar
Default How about...
Making the input a 6SL7 LTP, to a 6SN7 CF Driver, to the 6V6 with 12v battery fixed bias and the screens to the UL taps. Wouldn't be that much more in terms of complexity... (And maybe some Shade...)
Athos
Old 25th October 2010, 08:34 PM   #22
boywonder is offline boywonder  United States
boywonder's Avatar
Originally Posted by lawbadman View Post
I did actually consider that amp but I got scared when I saw it needs a -160Vdc. That means I would need an extra high voltage trafo, and im trying to keep costs down.
Do a search for the 6GK5/6V6 music machine. It's the updated version, and only needs -66V for the CCS. I've built the 6GK5/EL34 version, and it's the nicest sounding amp in the collection so far.
The -66VDC is supplied by a tiny 44V toroid.
6v6 music machine build help!
Old 25th October 2010, 08:51 PM   #23
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
In the overall costs of implimenting the music machine (as it should be done), an additional small trafo is negligible. It doesn't need to be a high power piece of iron since its only setting up a voltage for the first stage - some 15ma if I recall correctly.
Poinz does some very convoluted connections to make a couple of common PTX's work, but the required combinations can be acheived in a number of ways.
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 25th October 2010, 09:30 PM   #24
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
Originally Posted by stalker View Post
Where did you read it? I have serious doubts about that.
Gernsback Library Inc.
april 1956
Crowhurst and Cooper
"High Fidelity Circuit Design"
chapter 6
Drivers and Inverters
I'm not arguing against, I actually like the Mag style, and I believe it sounds very good, even with theoric weaknesses..
"It is less serious than if worst"
Old 25th October 2010, 09:43 PM   #25
Athos
So, completely redesign it then? Sounds like a complex response to a simple problem - the 6V6 doesn't need huge voltage at G1 to drive it, just an appropriate driver/splitter. Why throw another pair of tubes at the issue? Ditch the SL7 and go SN7 voltage amp to SN7 concertina splitter. Job done.
Old 25th October 2010, 09:47 PM   #26
athos56's Avatar
Sorry, half snark, should have left it alone
Athos
Old 25th October 2010, 10:32 PM   #27
ayieeee, we are all guilty at some stage! :-)
Old 26th October 2010, 12:45 AM   #28
Eli Duttman is offline Eli Duttman  United States
May I immodestly intrude?
Check "El Cheapo" out. The 12AT7 has a higher gm than either the 6SL7 or the 6SN7. High gm and low RP make for better performance in a driver.
For all practical purposes, the 'AQ5 shown in the schematic is a 6V6 in a 7 pin mini package. Zero parts value changes are needed to build with 6V6s.
Triode wired "finals" yield approx. 6 WPC. If the O/P tubes are set up in ultralinear mode, about 12 WPC are available.
Eli D.
Old 26th October 2010, 03:00 AM   #29
lawbadman is offline lawbadman  Jamaica
lawbadman's Avatar
Thanks for the suggestion Eli.
What are the voltages (or range of voltages) for B+, B2+ and B-?
Old 26th October 2010, 07:50 AM   #30
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Originally Posted by rmyauck View Post
Tube rolling might improve it and I don't know way the first cap after rectifier is so high! I think it should be 30.
I've seen that a lot with these old designs. They were trying to build it on the cheap, and resistors are a good deal cheaper than ripple chokes, but half as effective for ripple attenuation. They abused the hollow state diodes with over sized reservoir capacitors. They were counting on an atechnological public to be unaware that having to constantly replace the 5Y3s wasn't normal. It didn't hardly matter when you could go to any grocery store, pharmacy, radio/TV repair shop and get replacements for a $1.50 (or whatever they cost).
Of course, a big reservoir capacitor like that is going to bust the specs for Isurge. That should be less than half that size. 34uF behind a 5U4GB comes to something like 815mA of Isurge, and that one is rated for a max of 1.0A of Isurge.
You need to get that capacitor down in size, and use an LRC ripple filter. If you want to keep it cheap, then consider an active decoupler after the reservoir capacitor.
There are no foxes in atheistholes
www.dolphin-hsl.com
Have anyone built this 6V6 amp?Hide this!Advertise here!
Trouble with amp 6V6 Tachyon Tubes / Valves 12 13th October 2008 05:25 PM
new 6V6 amp sorenj07 Tubes / Valves 7 11th September 2007 02:09 PM
6V6 guitar amp... Guiness Instruments and Amps 3 24th November 2003 08:31 AM
6V6 Guitar Amp SHiFTY Instruments and Amps 2 5th August 2003 02:10 PM
