GU-50 in Single-Ended Triode Configuration - What bias points?
Old 27th October 2010, 09:32 AM   #31
ErikdeBest is offline ErikdeBest  Switzerland
Hello!
That blog is not mine! I just looked for the triode curves of the GU50 on google and found the link, which shows the curves, some loadlines and further comments, very handy information for the thread starter.
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 27th October 2010, 04:44 PM   #32
Pano is offline Pano  United States
Pano's Avatar
OT and personal attacks deleted. Yellow flags issued.
Stick to the subject, keep away from personal remarks.
Old 27th October 2010, 05:20 PM   #33
quikie22 is offline quikie22  Malaysia
Thanks panomaniac.
Old 28th October 2010, 02:14 PM   #34
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I am guessing you guys didn't get the message the first time. Please read post 33 again. If the rules are broken, you will spend time in the penalty box. The amount of time you spend there will be determined by how badly you choose to break the rules.
Fair enough?
planet10 needs your help:
Let's help Ruth and Dave
Old 5th November 2010, 05:07 PM   #35
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Here you go.
www.wavebourn.com GU-50 Single Ended Amplifier Design
The Devil is not so terrible as his math model is!
Old 6th November 2010, 07:03 PM   #36
artosalo is offline artosalo  Finland
artosalo's Avatar
It seems that one alternative to make GU50 working as a triode with high anode voltage has been not presented yet. The pentode tube can also be connected as a triode by connecting screen and control grid together.
This connection forms GU50 as a "hi-mu" triode resembling much like 811A. In such connection the mu of the triode connected GU 50 is around 200...250. It requires some power to be driven and positive bias of some 7 to 8 volts when operated with 800 V anode voltage, but these are not too difficult to accomplish.
As many readers possibly know, GU50 is originally a German WW2 era tube namely LS50. It's datas can be found from the following site: http://www.mif.pg.gda.pl/cgi-bin/vs4.pl
At the last page of the data available from there (section 14. ), you can find this data.
I have built such SE-amplifier with GU50 and Edcor GXSE15-8-10k transformer and the results were very satisfying. The available output power was about 15 W.
Old 6th November 2010, 09:30 PM   #37
Wavebourn's Avatar
Right.
If to connect all 3 grids together you can make a right-handed triode. I know that amps with pair of such "triodes" were giving 200W of output power.
Old 7th November 2010, 01:06 AM   #38
45 is offline 45  Italy
45's Avatar
Maybe because who started this 3d is newbie?
Where is the advantage in comparison to the pentode connection? You still end up with 40-50 Kohms plate resistance I guess and same maximum plate dissipation (40W) with the additional complication of positive grid bias...!!
45
Old 7th November 2010, 02:41 AM   #39
This was what I heard of at first. If you look at my original post, this was the thing I was thinking of. A high voltage Triode mode for GU-50. Which i have been strongly discouraged from doing due to the dangers :-)
Old 7th November 2010, 04:06 AM   #40
Wavebourn's Avatar
If you don't afraid...
GU-50 in Single-Ended Triode Configuration - What bias points?Hide this!Advertise here!
Power cord for single ended triode kimobuddy Tubes / Valves 1 11th April 2009 06:47 PM
Running Single Ended 6V6 in Triode Mode WRyan Tubes / Valves 19 10th February 2009 05:09 PM
6S3B-V Wire-Ended Single-Triode tube Alastair E Tubes / Valves 3 11th June 2007 08:48 PM
Best Cheap Speaker for Single Ended Triode Patrick Bateman Multi-Way 16 22nd December 2006 09:17 PM
DIY Single Ended Triode Designs jesserparker Tubes / Valves 35 23rd March 2004 12:21 AM
Copyright ©1999-2017 diyAudio
