| diyAudio Sponsor | ||
hi anyone knows where to buy the resistors of 880 ohms and 50w for 300b
Angela besides instrument.gracias |
#2 |
Mouser has 880 Ohm 25 Watt chassis mount Dales in stock. Four in series/ parallel will give you 880 Ohms@50Watts.
Craig |
#3 | |
This resistor will get very hot. I'd recommend oversizing it. 4 in a series/parallel combination is a good idea unless you have a large heatsink. It's difficult to find standard axial carbon or metal film resistors at that power level. DON'T use wire wound inductive resistors. Make certain they are a non-inductive type. |
#4 |
Make that 100 watts. Wattage is additive whether in series or parallel.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#5 |
I knew that.
Craig |
| 15 ohms (12 on ohmmeter) with 24 ohms resistor in parallel to bring to 8 ohms | McIntosh Man | Multi-Way | 29 | 11th June 2010 05:36 PM |
| Determining cathode resistor | bereanbill | Tubes / Valves | 5 | 27th April 2009 11:33 PM |
| What is the RIGHT way to calculate the Value of the cathode resistor? | sgerus | Tubes / Valves | 22 | 18th December 2008 08:04 PM |
| Wirewound cathode resistor | Klimon | Tubes / Valves | 12 | 30th August 2006 10:19 PM |
| Problem with cathode resistor | liberty | Tubes / Valves | 3 | 9th September 2005 01:37 AM |
| Page generated in 0.08173 seconds (76.80% PHP - 23.20% MySQL) with 10 queries |
