| diyAudio Sponsor | ||
As I understand it the 6c45pi and SM5842 need a small grid leak, best around 50k. For a small spud amp would it be OK to just use the input volume pot as the gridleak if it is about 6" away from the tube? Or does the gridleak need to be near the tube as possible like the grid stoppers to counter the HF oscillations these tubes are known for.
#2 |
The grid leak does not carry RF. It can be placed anywhere, minding general wiring rules.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 |
Don't just use the pot as a grid leak, as one of the normal failure modes is for the wiper to lose contact with the track. Add a resistor from wiper to ground too, about 10-20 times the pot resistance. Then you still have some bias when the pot fails.
A valve which requires a small grid leak is clearly expected to have significant grid current so it will need a low impedance source, in order to avoid distortion. I would use a 10K pot, with 100K from wiper to ground. |
#4 | |
Thanks. |
| When to use a grid leak resistor? | bequerel | Tubes / Valves | 8 | 25th April 2009 01:09 AM |
| Value of grid-leak resistor | hkoetz | Tubes / Valves | 4 | 11th January 2009 04:15 PM |
| 5842 grounded grid | alexg | Tubes / Valves | 19 | 27th April 2007 11:49 PM |
| Value of grid leak resistor | Klimon | Tubes / Valves | 4 | 10th November 2006 04:40 PM |
| How to determine grid leak current? | arnoldc | Tubes / Valves | 4 | 10th March 2005 10:34 PM |
| Page generated in 0.06371 seconds (76.02% PHP - 23.98% MySQL) with 10 queries |
