KT88 SE Complete Kit
Old 11th November 2010, 10:15 PM   #51
scott17 is offline scott17
Here is a list of the parts included in the basic parts kit:
1 - Assembly Manual on CD
Resistors - Vishay
2 - 220K 1/4W Metal Film 1%
2 - 100R 1W Metal Film 1%
4 - 1K 1/2W Metal Film 1%
2 - 1.5K 1W Metal Film 1%
2 - 47K 3W Metal Film 1%
2 - 560R 10W Wirewound 1%
1 - 10R 5W Wirewound 5%
2 - 1M 1/4W Metal Film 1%
Capacitors
1 - 30uF Oil Filled Metallized Polypropylene
2 - 50uF Oil Filled Metallized Polypropylene
2 - 10uF 630V Audio Aluminum MP Film
2 - 0.22uF 630V Audio Aluminum MP Film
2 - Elna Silmic II 100uF 25V
2 - Elna Silmic II 220uF 100V
1 - 0.1uF 400V Orange MP
2 - 0.1 uF 630V MP
Connectors, Hardware, etc.
1 - IEC Power Entry EMI/Fuse
2 - Neutrik RCA Socket
4 - Speaker Binding Post
1 - DPDT Toggle Switch
1 - Belton 9-Pin Socket
3 - Belton 8-Pin Socket
2 - 2 Capacitor Clamp
1 - 1.5 Capacitor Clamp
2 - Turret Board
1 - Aluminum Knob
1 - 100K Alps Volume
1 - 2A Slow Blow Fuse
2 - 5H Driver Choke
1 lot - interconnecting wire, terminals, hardware
Originally Posted by scitizen17 View Post
I have finalized the cost for the basic parts, less transformers and chassis. This will include a detailed layout and assembly instructions provided on CD. I am in the process of assembling the amp and will document the process throughout with photos and written instructions.
I am still in the process of hopefully obtaining the custom lay-down style transformers. It's proven to be a little difficult. In the meantime, the transformers I will be using for the initial build are:
1 - Edcor XPWR010-120/240 Power XFMR
1 - Edcor CXC125-10H-200mA Filter Choke
2 - Edcor GXSE15-6-5K 15W Output Transformer
The Edcor GXSE have a 40-18K Hz frequency response. The transformer I hope to end up with will be 20-20K Hz frequency response. It will be interesting to see how the GXSE units perform compared to the 20-20K Hz units I have in my current build. I have read good reviews from people that are using them. Edcor does offer the CXSE25-8-5K, for a little more than double the cost of the GXSE, with a 20-20K Hz frequency response. My thought is that if the GXSE units perform well, it may provide a low-cost alternative. I have looked into possibly providing an aluminum adapter plate that would allow the GXSE unit to be used on my chassis design.
I made a couple of parts changes from my initial post. I have decided to include a volume control, and I have changed the Caddock 560 ohm 10W resistor to a Vishay 560 ohm 10W wirewound resistor to keep the cost under control. Again, when this build is complete I will compare to the unit I have now using the Caddock device. I suspect since the resistor is bypassed, it will make no audible difference.
I have completed the preliminary chassis design and will have to wait until the transformer issue is resolved before I can finalize. I have attached a sample of the layout. The sample does not include most of the dimensions and details that will be included in the kit.
In the next few days I will be photographing the parts kit and I will post it here. Since we are talking about money now, I will eventually have to move this thread to the Vendor Forums section.
The cost for all parts and assembly manual, less transformers, tubes, and chassis will be: $319.00
To include (2) Electro-Harmonix KT-88, (1) Electro-Harmonix 5U4-GB, & (1) Soviet 6N1P-EV add $90 for a total: $409.00
FYI: This amp will run the EL34 tubes and they are about half the cost, but to my ear the KT88 has much more punch, deeper bass, and better overall clarity.
FYI#2: The Edcor transformers I have listed above are about $200.00 + shipping directly from Edcor.
Old 12th November 2010, 04:43 AM   #52
MashBill is offline MashBill  United States
MashBill's Avatar
Nice! I am still interested although I would prefer the input jacks to be on the rear of the chassis. Also, I would prefer no volume control.
Old 12th November 2010, 11:41 AM   #53
parb is offline parb  United States
it looks interesting. im also of the school that inputs and outputs belong on the rear. looking forward to the pics so i can determine if im keen on a chassis included or not.... but im definately still interested.
Old 12th November 2010, 05:33 PM   #54
mantisory is offline mantisory
I would also be interested in this kit (complete)
b
Old 12th November 2010, 09:53 PM   #55
cmetzner is offline cmetzner
I am also interested. Looking for another project
Old 13th November 2010, 01:07 AM   #56
The inputs will be relocated to the real panel. The volume control and power switch will be relocated to the front panel.
Old 13th November 2010, 03:53 AM   #57
MashBill's Avatar
Great news! I can definitely live with that. Thanks for putting this kit together. It should make for a nice winter project.
Old 13th November 2010, 12:53 PM   #58
eleftherios is offline eleftherios
i am intresting about it to and i am waiting
Old 13th November 2010, 12:55 PM   #59
thank you
Old 19th November 2010, 08:57 PM   #60
Here is a photo of the basic parts to be included in the kit. The photo also shows the tubes that will be included if that option is selected.
The chassis has been finalized and the design has been accepted by the manufacturer. There is a lead-time of 6 weeks for the chassis.
Still awaiting production times for the custom transformers. At this point it looks like the initial build for this will still be with the standard Edcor transformers. I will custom cut a chassis so I can get the manual completed as soon as possible, in order to start offering the basic kit.
Thanks for your patience and support.
KT88 SE Complete KitHide this!Advertise here!
Best Complete KT88 Amp Kit under $1K? ZenZoo Tubes / Valves 8 2nd December 2012 12:14 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
"Complete" SE KT88 Sherman Tubes / Valves 12 26th February 2005 09:52 PM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
