KT88 SE Complete Kit - Page 28 - diyAudio
Old 13th December 2012, 09:07 AM   #271
regiregi22's Avatar
Originally Posted by scott17 View Post
Great! Yes the transformers are definitely "beefy". Just wait until you get the OTs.
When I spec'd these to the manufacturer, I made sure they were premium.
In my opinion, the manufacturer was a little "lax" in the lamination finish, so you may want to refinish them. I've refinished the ones I've used. It's not that big of a deal to do.
Anyway, keep me posted.
Scott
What can you suggest to improve them in that aspect?
Best regards!
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 13th December 2012, 03:07 PM   #272
I just use a razor blade to smooth off the rough spots, then I put on a couple of coats of satin-finish varnish.
My cousin painted his with semi-flat hi-temp black paint.
Best regards!
Old 14th December 2012, 08:22 AM   #273
regiregi22's Avatar
Ain't it dangerous to scrap those laminations, in the sense of shorting laminations? I mean, afaik laminations are insulated between them, right?
Old 14th December 2012, 01:50 PM   #274
Yes, they are insulated by the oxide coating.
I'm not talking about using a belt sander here. I am not shorting the laminations, just scraping off the high spots of existing rough varnish.
Old 14th December 2012, 02:45 PM   #275
freax's Avatar
Good to know I would've just hit them with some sandpaper and sprayed them.
Now I know better than to cause a dead short.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 14th December 2012, 08:46 PM   #276
That is why I just use a single edge razor blade to cut away the high spots and drips. I go in the direction of the lams, not across them. I'm not actually getting into the metal. It's not hard to do.
Old 4th February 2013, 04:23 PM   #277
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
I got some sanding blocks to knock off the "run" that looks to be at one corner of the transformer lams. I do understand the need to avoid shorting the laminations. I got some flat black hi-temp spray paint for these, and the motor run caps.
Question - should I make sure that the clamps for the motor run caps make electrical contact with the cap for grounding purposes? I could either tape off a section of the cap below the level of the chassis, or sand off some of the paint before mounting.
Old 4th February 2013, 09:31 PM   #278
julcat is offline julcat  Mexico
Does the master kit is still available?
Old 5th February 2013, 03:39 PM   #279
Yes. Either method will work.
Old 5th February 2013, 03:40 PM   #280
I sent a PM to you.
Best Complete KT88 Amp Kit under $1K? ZenZoo Tubes / Valves 8 2nd December 2012 01:14 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 03:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 01:26 PM
"Complete" SE KT88 Sherman Tubes / Valves 12 26th February 2005 10:52 PM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 09:19 AM
Copyright 1999-2017 diyAudio
