KT88 SE Complete Kit
Old 2nd December 2012, 03:52 AM   #261
freax is offline freax
freax's Avatar
found these, might have to do a trip down to the local hardware store: Stainless Steel Round Base Plate w/ cover Suit 2" Tube | eBay
2 inches = 50mm, size of kt88 base = 48mm
and take the chassis down with me to see how they look.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 4th December 2012, 02:56 AM   #262
freax's Avatar
Is there a good reason why a 5U4-G couldn't be put in place of the GB?
http://www.fourwater.com/files/fullrect.txt
The G has a max plate mA of 225mA vs the GB's 275mA, is the schematic that tightly wound that it cannot accomodate an older coke bottle style G model?
The vdrop is different aswell, 44v on the G vs 50v on the GB, will putting a G model in substantially increase the B+ to the point that it would cause issues?
Would increasing the B+ by 6-12v make that much of a difference?
I've been thinking about ways to fuse the B+ line in the event that an older coke bottle style has an internal short, also I've read that monitoring the power transformer's temperature is a wise idea when doing things such as this.
Thank you for your advice.
Old 4th December 2012, 03:32 AM   #263
scott17 is offline scott17
The total current draw for this amp is approximately 150mA.
Both rectifiers will meet this specification.
The total plate supply resistance for a 5U4G is a little higher than the 5U4GB.
The power transformer secondary resistance of 50 ohms correlates with the 5U4GB at 400V.
You will need an additional 20 ohms of series resistance if you use the 5U4G.
See the data sheets for this information.
Other than that, it will work just fine.
Old 4th December 2012, 03:59 AM   #264
freax's Avatar
thanks for that, wouldn't the resistance of the choke add series resistance though?
scratch that, I see the schematic now and its capacitor input, so it applies.
i'm looking at the datasheets now of both G & GB.
I'll do a few simulation runs tonight in PSUD and see how much 20 ohms will need to dissipate.
Old 4th December 2012, 04:10 AM   #265
The concern here is the series limiting resistance for the connection between the power transformer secondary to the plates of the rectifier.
A 20R/2W should be fine here, but I would make it a 3W just to keep things on the cooler side.
Old 4th December 2012, 04:25 AM   #266
This (or something matching it) will work fine:
PR03000202009JAC00 Vishay/BC Components | Mouser
or this:
http://www.mouser.com/ProductDetail/...fEJMcOI0Q7U%3d
Old 13th December 2012, 01:30 AM   #267
freax's Avatar
Just got my Power transformer and choke trafo, holy cow! this is heavy, Its heavier than the 600va toroidal that I bought from Antek a few months ago.
I'm still waiting for everything else to arrive (probably tomorrow)
It was very well packed.
Old 13th December 2012, 01:57 AM   #268
Great! Yes the transformers are definitely "beefy". Just wait until you get the OTs.
When I spec'd these to the manufacturer, I made sure they were premium.
In my opinion, the manufacturer was a little "lax" in the lamination finish, so you may want to refinish them. I've refinished the ones I've used. It's not that big of a deal to do.
Anyway, keep me posted.
Scott
Old 13th December 2012, 02:05 AM   #269
freax's Avatar
Scott
Now that you mention it, yes the core finish is quite a bit thin, I've got just the thing for it too, an epoxy paint.
That means I'll have to wait 2 more weeks before I can start assembling, ugh... the cans of epoxy are expensive, as is the chrome paint that I've been eyeing off, oh well the things we do for looks
Maybe I should rethink everything, I'll sleep on it anyway.
Old 13th December 2012, 02:26 AM   #270
That will no doubt be great. I just use a razor blade to sluff of the high spots and finish with a poly.
When my cousin refinished his, he just smoothed them out and finished them with hi-temp semi-flat. His photos are towards the end of the Vendor's forum thread. By the way, I think we should be posting there actually.
KT88 SE Complete KitHide this!Advertise here!
Best Complete KT88 Amp Kit under $1K? ZenZoo Tubes / Valves 8 2nd December 2012 12:14 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
"Complete" SE KT88 Sherman Tubes / Valves 12 26th February 2005 09:52 PM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
