KT88 SE Complete Kit
Old 29th November 2012, 02:35 AM   #251
scott17 is offline scott17
I found this while searching:
http://67-72chevytrucks.com/vboard/s...d.php?t=382386
If it really looks like that, it might be cool.
Old 29th November 2012, 01:10 PM   #252
freax is offline freax
freax's Avatar
Originally Posted by Dave R View Post
The sound is what's most important to me. I'm extremely happy with it. You'll be glad, too.
Dunno about you guys but when I flick that big power switch I wanna hear a big thud and have a reflection in my amp so I can see my own smile.
Its a turn on.
Ba dum tisss. http://www.youtube.com/watch?v=6zXDo4dL7SU
I've spent a while on ebay and found this:
Mix Chrome Plating Solution to 33 Oz | eBay
its an electroplating kit, you just gotta give it 4-15v DC at 5-15 amps for 5 seconds.
only problem is the anal-retentive australian customs probably won't let me import it.
There is also:
Copper: http://www.ebay.com.au/itm/Mix-Coppe...item1e63efeade
and Brass: http://www.ebay.com.au/itm/Mix-Brass...item1e744eed11
and Nickel: http://www.ebay.com.au/itm/Mix-Nicke...item1e640140bf
And then there is a spray on chrome:
http://www.ebay.com.au/itm/Refill-A-...item1e71ed14ee
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 29th November 2012, 02:16 PM   #253
freax's Avatar
There is also: kx-928 items - Get great deals on Category 1 items on eBay Stores!
Remember to make sure that you add a nickel or copper layer to the amp chassis before you use these electroplating kits, as they will only adhere to a copper or nickel surface!
Old 30th November 2012, 06:18 AM   #254
freax's Avatar
I woke up this morning thinking about nothing but brass, steampunk, and leather
and curtain eyelets.
Old 30th November 2012, 10:30 AM   #255
jrn77478 is offline jrn77478  United States
Steampunk...
Now you're talking.
Old 30th November 2012, 10:51 AM   #256
freax's Avatar
2pcs 500?A Panel VU Meter Warm Back Light Recording & Audio Level Amp | eBay
50 X COPPER BOILER RIVET'S, GENUINE MAMOD sealed end | eBay
I need to get the chassis and think about things before i can go any further, not even sure if those two meters will fit into the chassis.
Rivets are to hold down the meters + hold down some copper plates for R/L inputs, R/L outputs, mains cable, don't worry it will be well secured to the actual chassis.)
I could put the volume control ontop, to the far left, that will get it out of the way of the front panel.
bnew vintage mains cord: http://www.ebay.com.au/itm/OLD-GOLD-...item2a1d09eaf6
DPDT mains HPM b/new switch: http://www.ebay.com.au/itm/antique-c...#ht_1829wt_689
Or: http://www.ebay.com.au/itm/brass-lig...item19d6de87dc
These /could/ be used to flush off the leather around each tube, but the KT88's have a larger base which is 48mm in diameter (I'm led to believe), so you would need to drill out a pretty large hole out of these: http://www.ebay.com.au/itm/round-ced...item19d6a66409
They are also fairly tall and might end up hiding too much of the tube, the KT88's would be fine tho they have that big base of theirs.
I'm still on the lookout for something to flush/finish off the leather which would go ontop of the chassis, remember that for the 5U4 tube it hasn't got much space inbetween the tube socket and the power transformer/choke.
I might just break out the dremel and get a hole punch and cut up some copper rings to go around the tubes that I can then bolt down with nuts/bolts. I would need to make at least 4x of these though, of differing sizes, maybe including a couple for the front VU meters, and the volume control.
The leather can be tucked in underneath the transformers pretty easily, so thats not much of a concern, I can also use washers to give it some lift above the leather.
These could hold the leather down to the chassis: http://www.ebay.com.au/itm/Tandy-Lea...item2c639f28b8
Then use some copper reinforcing strip and some copper rivets to finish off the edges on either end of the chassis and bolt/nail down the leather to the wooden pieces through the copper reinforcing strip.
http://www.ebay.com.au/itm/1767-10mi...item2a11c86f1a
And of course non-flammable foam can be used to buff up the leather to give it that briefcase look.
Old 30th November 2012, 11:16 AM   #257
I built this recently. Not really steam punk, not sure what it is. A mess actually.
Anyway, for what it's worth.
Scott
Old 30th November 2012, 11:21 AM   #258
freax's Avatar
If I may add some creative critisizm:
It looks nice, the chassis does and so do those tube socket finishes, then your eyes hit the transformers/fake gold paint/capacitors, then it loses its high-class edge.
strip off all of that paint on those components only and try again.
Oh and replace that volume control with something else, possibly birch, it looks like it came off a 1980s amplifier, it does not belong there.
Where did you get/what type are the edge protectors?
Old 30th November 2012, 11:29 AM   #259
That's exactly what I thought after I saw it put together. Actually my eyes hit the transformers/capacitors first. Luckily I have not wired it yet.
Here are the brass corners.
Stanley Hardware #1 Solid Brass Corner: Amazon.co.uk: DIY & Tools
Old 30th November 2012, 11:30 AM   #260
freax's Avatar
Cheers
KT88 SE Complete KitHide this!Advertise here!
Best Complete KT88 Amp Kit under $1K? ZenZoo Tubes / Valves 8 2nd December 2012 12:14 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
"Complete" SE KT88 Sherman Tubes / Valves 12 26th February 2005 09:52 PM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
