KT88 SE Complete Kit
Old 29th February 2012, 11:05 PM   #221
scott17 is offline scott17
Originally Posted by regiregi22 View Post
Sure, but I am asking about voltage developed across the 10 ohm resistor. Will it survive to blow the fuse? If it doesn't matter, why is it there?
I mean, why don't just skipping that resistor?
The RC ground breaker from signal ground to the chassis is for ground loop noise reduction. The voltage across the resistor is in the millivolt range. The capacitor in parallel is for RF rejection. I don't know what you mean by "survive to blow the fuse". Will "what" survive to blow the fuse? The chassis is at earth ground. You can leave the filter out if you wish and connect the signal ground directly to the chassis.
Old 1st March 2012, 11:00 AM   #222
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
I mean that if it is possible to DON'T put the resistor and just put the capacitor for RF filtering
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 1st March 2012, 11:19 AM   #223
Cassiel is offline Cassiel  Libya
Sell a kit and you'll get annoying questions. Such is life.
Old 1st March 2012, 12:33 PM   #224
regiregi22's Avatar
Just in the event you don't get a shock in a not properly failure proof designed system, yes, life will continue. In such a way
I am not saying this grounding scheme is not safe, just that I am too curious some times
Old 1st March 2012, 01:42 PM   #225
bayermar is offline bayermar  Germany
bayermar's Avatar
You can't leave the resistor out just like that - your signal ground would be ill-defined. You would have to replace it by a piece of wire (the cap would be useless then) to ensure that ground reference for your audio path is defined.
From a safety point of view this is quite irrelevant. Important is the safe and sound connection of the earth wire of the 3-wire power cord to the chassis.
Any failure causing a meaningful charge/voltage on the chassis will blow the fuse - and that's what you want.
In practical terms, signal ground and safety ground are on almost the same potential. The resistor lifts signal ground a few mV above earth ground level helping to break ground loops (as scitizen17 stated earlier).
Martin
Old 1st March 2012, 02:49 PM   #226
regiregi22's Avatar
Originally Posted by bayermar View Post
You can't leave the resistor out just like that - your signal ground would be ill-defined.....................to ensure that ground reference for your audio path is defined.
Why would I NEED to reference PS ground to Protective earth? My audio signals can be referenced to power supply ground and completely isolated from protective earth, and will sound good. Even using an input audio transformer, it will provide galvanic ground isolation, so the amp will be totally floating.
Sooooooo..... if there's no real need to tie PE (Protective Earth) and PS-GND (Ground side of PSU capacitors) regarding audio performance, then the need should came from safety issues.
Pardon me if I get boring with this matter
Old 6th March 2012, 10:07 AM   #227
regiregi22's Avatar
I would recommend reading that article, is the solution I've always implemented and I am going that route with this amp too. Don't really like the idea of NOT providing a direct path for current from the 0 volts rail to Protective Earth.
Earthing (Grounding) Your Hi-Fi - Tricks and Techniques
Old 6th March 2012, 10:59 AM   #228
If that's the solution you've always used, why all the questions? No one here ever suggested to NOT provide a direct path for current from the 0 volts rail to Protective Earth.
The grounding scheme for the kit has always included a direct current path from circuit ground to chassis ground.
Old 6th March 2012, 09:48 PM   #229
faithintruth is offline faithintruth  Canada
I'm interested in the kit.
Old 10th April 2012, 01:09 PM   #230
regiregi22's Avatar
I can't agree with that, there's no direct path, there is a 10 ohm resistor.
KT88 SE Complete KitHide this!Advertise here!
Best Complete KT88 Amp Kit under $1K? ZenZoo Tubes / Valves 8 2nd December 2012 12:14 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
"Complete" SE KT88 Sherman Tubes / Valves 12 26th February 2005 09:52 PM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
