KT88 SE Complete Kit
Old 7th January 2011, 09:44 PM   #171
scott17 is offline scott17
Originally Posted by Rullknufs View Post
I'm also interested in this, but i need a little more than 10WPC. I'd prefer around 20WPC, is that possible?
This amplifier will produce a little more than 10WPC, like maybe 11-12WPC in the ultralinear mode, but it will not approach 20WPC. Loudspeaker sensitivity is a big factor in listening level however.
Old 8th January 2011, 09:11 AM   #172
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
I have a pair of CSS EL70 in Mar-Kel70 boxes.
Old 10th January 2011, 08:35 PM   #173
pred is offline pred  Switzerland
Is this posible to be used on 230V? How much is the shipping to Switzerland, Are the tubes included?
Pred
Old 10th January 2011, 10:11 PM   #174
Pred
The master kit @ $849.00 USD includes chassis, transformers, tubes, assembly manual and all parts. The power transformer can be wired for 120V or 240V at 50/60Hz. At 120V the B+ is 420VDC. Running at 230V instead of 240V would yield about 402V according to calculations which is just fine. The kit is shipped in 3 boxes with insurance. To Switzerland the cost, per box, via USPS, 3 - 5 days is $83.30 + 63.00 + 63.00 = $209.30 USD. Seems kind of high, but that's the best I can do.
Old 10th January 2011, 10:28 PM   #175
Default KT88 SE Kit
I getting so close to offering this as a valid product I think I should move this thread over to the Vendor's Bazaar forum, so that's where I'll be from now on.
Thanks,
Scott
Old 11th January 2011, 09:21 AM   #176
Mikael Abdellah is offline Mikael Abdellah  Sweden
hehe.. nice to see the work you are doing and that you all like the amp. at the moment another hobby takes up most of my time, but i think i will continue with diy audio projects for as long as i live. keep the spirit alive!
Old 12th January 2011, 05:44 PM   #177
Hello,
thank you for the answer, but this is steep for me...
Old 12th January 2011, 11:25 PM   #178
Thanks Mikael!
Scott
Old 12th January 2011, 11:29 PM   #179
Hello,
You are welcome. It is a little expensive, but well worth the components that are included, and it sure does sound good!
Thanks for considering,
Scott
Old 13th January 2011, 05:18 PM   #180
Default Chassis Depth
An important fact about the Basic Kit.
If you are providing your own chassis, make sure that it is at least 17"W X 10"D X 3"H.
Thanks,
Scott
KT88 SE Complete KitHide this!Advertise here!
Best Complete KT88 Amp Kit under $1K? ZenZoo Tubes / Valves 8 2nd December 2012 12:14 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
"Complete" SE KT88 Sherman Tubes / Valves 12 26th February 2005 09:52 PM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
