KT88 SE Complete Kit
Old 16th December 2010, 10:26 PM   #101
scott17 is offline scott17
Originally Posted by nic6paul View Post
Who manufactures your new transformers?
The raw transformers are made in USA by Heyboer. I purchased mass quantities of end bells separately and had them powder coated with RAL9006 which is a metallic called White Aluminum. Looks very nice, similar to a pearlescent finish.
Old 16th December 2010, 10:32 PM   #102
Originally Posted by Rockmore View Post
Also, dont know what your sourcing is for a majority of your parts and the chassis, but have you communicated with this guy?: cnc aluminium chassis for tube amps Some of his CNC work would look and be great if it was powder coated! And he is as enthusiastic as this thread is also to "mass produce". Now if I could just find a decent woodworker for the other portions of the chassis...
The chassis that will be part of the full kit will be raw aluminum with walnut side panels. You can see a photo at post #82. As far as the woodworking you might want to get in touch with "jmillerdoc" who is a member here. He does excellent work.
Old 16th December 2010, 10:40 PM   #103
Originally Posted by Gobble View Post
I am interested - if you are willing to skip the power trafo from the kit. Interested in the chasiss though, so not the basic kit you offered but almost the full kit minus the Trafo.
I would like to source one locally to reduce shipping weight.
The chassis I will be offering will be precut for the lay-down style transformers as pictured in post #97, so unless you can source this style in the exact size, your only option to be able to use this chassis would be to custom cut an aluminum plate that would cover the transformer cutout and mount with the existing transformer mounting holes. You could then mount a standard stand-up transformer to the plate. This was something I had looked into briefly but I have been so busy trying to get this initial build going, that option is kind of on the back-burner for now, so to speak.
Old 17th December 2010, 01:08 AM   #104
Originally Posted by Structo View Post
Looking good!
I like your avatar. It reminds me of something I did once as a toddler. It must have made an impression since I still remember it to this day!
Old 17th December 2010, 02:08 AM   #105
Originally Posted by neonthecat View Post
The ebay offering is for a partial, "Made In China", PCB. There is no valid comparison with the comprehensive kit Scott is offering, price or otherwise.
Old 17th December 2010, 06:19 AM   #106
Gobble is offline Gobble  India
If you can give me the dimensions for the power Trafo mounting holes, That will help me check with my vendor. I have a local vendor who makes R-cores.
Old 17th December 2010, 11:03 AM   #107
The power transformer is a standard EI 1-1/2" core, mounting hole centers are 3" X 3.75".
Old 17th December 2010, 03:02 PM   #108
daniloreyes is offline daniloreyes  United States
I'm in. Looks pretty good.
If it sounds good... Listen to it...
Old 20th December 2010, 08:14 PM   #109
Default SE Assembly Manual
Hello,
I am working diligently to complete the manual for this project. I thought that I would post the first few pages to let you get an idea of the format.
Happy holidays to all,
Scott
Old 21st December 2010, 12:13 AM   #110
howard99 is offline howard99  United States
Default beta builder
Just wanted to let you know if you need a guinea pig to build a kit, I would be happy to help. Never built a kit before the most has been wiring and soldering a crossover network. Your work looks good so far.
KT88 SE Complete KitHide this!Advertise here!
Best Complete KT88 Amp Kit under $1K? ZenZoo Tubes / Valves 8 2nd December 2012 12:14 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
"Complete" SE KT88 Sherman Tubes / Valves 12 26th February 2005 09:52 PM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
