Any high-end 6BM8 push pull tube amp schematic ? - Page 2 - diyAudio
Old 24th October 2010, 10:13 AM   #11
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Originally Posted by gaetan8888 View Post
Hello
I have a Pioneer SX-34 with a defect FM tuner section, since I did not find the problem of the FM tuner section, I would use the transfos and output tube to made a good tube amp...
As it is the SX-34 amp sound good but maby I can find a better schematic than the SX-34 amp section.
Any better push pull tube amp schematic than the SX-34 amp ?
I dont think it would need a 12AX7 input tube since cd player give arround 1 volt output and this voltage can drive the driver section of the 6BM8 tubes.
Here's a link to the schematic of the Pioneer SX-34;
AK Database PDF Gallery - Pioneer Receivers/Pioneer SX34 Schematic
Bye
Gaetan
These designs can be found somewhere on this forum. They both work/sound good. Headphoneamp is from Shoog
Old 24th October 2010, 08:34 PM   #12
Soonerorlater's Avatar
and put a zobel network at the output transformer secondary
Hi Gaetan, why did you think this was necessary and what values did you end up using
Hi Jaap, interesting 1st circuit, any more info
Brgds Bill
Old 24th October 2010, 11:17 PM   #13
Brgds Bill
Hello
If somebody borrow my amp and try it without connecting loudspeakers.
If this amp work without a load, and if there is some oscillations or rf noises at the input, the voltage of the output tubes can goes quite high and burn the output transformer primary winding.
I've use 10 ohm with 100 nf.
Bye
Gaetan
Old 24th October 2010, 11:26 PM   #14
Thanks for that
6v6 push pull guitar amp schematic sought guitar_joe Instruments and Amps 40 12th April 2013 07:26 AM
Fender push pull amp... using one tube only.. is it dangerous? akimball442 Instruments and Amps 2 3rd March 2007 06:45 PM
advice on an EL84 Push pull Amp schematic colin.hepburn2 Tubes / Valves 6 2nd June 2006 05:02 AM
Schematic needed PL519 Push-Pull Ultra-Linear amp mario2005 Tubes / Valves 0 15th May 2006 09:41 PM
ecl82/6bm8 push pull special designs Glass_painter Tubes / Valves 1 19th April 2003 07:45 PM
Copyright 1999-2017 diyAudio
