| diyAudio Sponsor | ||
Hello!
I'm trying to build a bassman100 amp but i can't find the 10k pot with 4 terminals to set the bias. I was wondering if i can do it in an other way with 2 normal 10k pots (Attched file), could somebody tell me if it is wrong and maybe how it could be done? I will appreciate any help, Jonas |
#2 |
The original circuit is strange. It adjusts the AC balance a little as well as the DC balance. I don't know how critical this is.
#3 |
How many knobs on this pot ... ? 2 wipers would tend to infer 2 knobs... some Alps pots have 4 terminals on them, but only one knob. Chinese copies are available, and probably better quality than the original.
#4 |
One wiper, plus a fixed centre tap?
#5 |
That is not the way I would have done it, but that's not the first time I've seen that bias setup. Its real advantage is that you have the current, in this case about 3.5mA, only going through a small portion of the pot, therefor it drops little current and can be low wattage and cheap. The double wiper pot really has only one function: to set the current through each tube to the correct value.
You could do a slight re-engineer to provide the same functions using two separate pots. I would try two 20k pots in parallel; one end to B- (omit the 3.3k resistor but not the cap) the other to the 15k resistor. The wiper goes to the 68k resistor. The pot will have to dissipate 2.7mA * 35V = .1W, so any well constructed 1W or 5W, 10k linear pot should do. I can't guarantee that the voltages will work out exactly as I described, but by juggling the 15k resistor, maybe 7.5k on either side of the pot, you should be able to get the pot in the center of its range when the amp is biased properly. |
#6 |
Leo Fender never paid extra for matched power tubes when he built amps. Random tubes were installed. The balance style bias control was there for hum null. It let you balance the amp with the random tubes, at least improve the balance. Set the control for least hum.
Many many guys have rewired the thing to a straight bias level control for all the tubes, and they just install matched sets. You can find that odd pot and duplicate this circuit, or build something else for bias. You can make something that adjust each tube separately, or something that has an adjustment for each side, or just one overall control. Only thing you MUST do is wind up with proper bias voltage on pin 5 of each power tube. |
#7 |
Yes the original is a pot ( so 1 knob) with 4 terminal, 1 wiper and a center tap.
Ok i will try to build a bias circuit with 2 pots with the values that Palustris has proposed. Thank you all for yuor help!!! |
| Bias Circuit Calculation | blue andry | Tubes / Valves | 26 | 6th July 2010 12:55 AM |
| Need confirmation on LED bias for circuit | phrarod | Tubes / Valves | 56 | 10th May 2010 02:03 PM |
| Help needed with bias circuit | Rob11966 | Tubes / Valves | 18 | 1st March 2009 03:07 PM |
| cathode bias circuit question | gary h | Tubes / Valves | 14 | 26th August 2008 12:36 AM |
| bias circuit for mosfet help | AudioGeek | Solid State | 2 | 29th April 2006 11:22 PM |
| Page generated in 0.08205 seconds (78.62% PHP - 21.38% MySQL) with 11 queries |
