diyAudio Sponsor
Old 20th October 2010, 04:02 PM   #1
bigwill is offline bigwill  United Kingdom
Smile A Radford STA15 restoration story
The amp first came to me in quite a mess...
The metalwork had HOLES in it, it was rusty, filthy and the wiring was shot.
Old 20th October 2010, 04:04 PM   #2
A complete strip down was required.
Old 20th October 2010, 04:10 PM   #3
The old PCBs were pretty shot with broken traces so I put considerable effort into making a prototype new design (using the original Radford circuit), with a few tweaks (CCS cathode biasing which turned out to be a more trouble than it was worth) and a better physical layout.
Meanwhile the metalwork I sent off to be chromed came back.
Old 20th October 2010, 04:14 PM   #4
Here are the runners with new valve holders and sockets installed. I even managed to use the original spacer with a new gold plated RCA/Phono socket!
Old 20th October 2010, 04:15 PM   #5
kevinkr is online now kevinkr  United States
kevinkr's Avatar
More, more, more!! Definitely want to see how this turns out..
www.kta-hifi.net
Old 20th October 2010, 04:16 PM   #6
A while later I got the chassis resprayed in a car auto place up the road
Old 20th October 2010, 04:22 PM   #7
Whoops this is backwards, but before I got the painting done I had to see to those pesky holes. The welding and grinding were not done by me
Also I feel silly for posting the previous pictures already because it gives the game away so quickly
Old 20th October 2010, 04:23 PM   #8
I have to go and do something outside but I will be back soon with more pictures!
Old 20th October 2010, 04:44 PM   #9
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Looks great with all the metalwork chromed, The pressings holding the valves are only zinc plated standard, and they easily stain with any moisture that gets on them.
My STA 15 had MK4 upgrade PCBs fitted and then stayed in my audio system for a pleasurable 20 years of use before exploding an electrolytic. It now sits on the shelf waiting to be repaired.
The Mk 4 PCBs are very similar to the Mk3 but had added bi-pass polypropylene caps on most of the electrolytics. Other mods that were recommended were hard wiring the output transformer impedance tap without the selector switch. They also supplied a new input socket, and heavy duty binding posts.
Old 20th October 2010, 04:55 PM   #10
kevinkr's Avatar
It looks really excellent, looking forward to seeing more pictures soon.
Will also be be quite interesting to read your impressions of the amplifier's performance once completed and put back into service.
That's real dedication to bring something back from the brink like this. I think many would have scrapped it for the transformers.
www.kta-hifi.net
KEF Reference 104/2; A restoration story glasswolf Multi-Way 23 27th April 2012 11:27 AM
Radford sta15 looking for a nice preamp... genitrini Tubes / Valves 3 2nd April 2010 01:30 PM
popping noise through 1 channel on Radford STA15 jives11 Tubes / Valves 5 28th September 2007 07:44 PM
Radford Audio Amps big jim Solid State 7 25th September 2006 05:31 PM
Radford STA25 Gram Tubes / Valves 4 15th August 2003 09:32 PM
Page generated in 0.09779 seconds (81.75% PHP - 18.25% MySQL) with 11 queries
