Mixed bias for balancing unmatched tubes in PPP?
Old 23rd October 2010, 04:48 PM   #21
athos56 is offline athos56  United States
athos56's Avatar
Originally Posted by 45 View Post
That was just the answer to your question. You can have a gap on the Edcor as well. You just need to find the practical solution which means enough inductance together with enough headroom in case of DC unbalance. You can start trying with 0.05-0.1 mm.
In your case you also have 8 power tubes to play with and I am pretty sure that if they measure within 10% one from any other for current and mutual conductance it will be easy and straightforward to make pairs so that you can find dynamic balance with little adjustment together with good DC balance using a single bias network for each pair.
45
And thanks for your answer. The tube cost alone is gonna hurt. I think your right about the tubes.
Athos
Mixed bias for balancing unmatched tubes in PPP?Hide this!Advertise here!
mixed mode bias TUBESMAN Tubes / Valves 4 6th October 2010 12:50 PM
ppp el84 fixed bias schematics jogas Tubes / Valves 17 31st August 2009 01:02 PM
mixed bias TUBESMAN Tubes / Valves 2 15th January 2009 01:19 AM
Will this work? "Mixed" 300B PPP IT ppereira Tubes / Valves 4 24th April 2004 05:29 PM
Balancing output tubes by changing heater voltage. Circlotron Tubes / Valves 8 10th February 2003 11:15 AM
