help troubleshooting gradually distorting tube amp (dropping b+ voltage when hot)
Old 20th October 2010, 01:30 AM   #11
Jim McShane is offline Jim McShane  United States
Originally Posted by diblet View Post
@DF96 i agree that the tubes look okay, but there is a little brown residue at the top and bottom that i don't see in any of the other tubes. maybe it is just being caught early enough were it isn't too bad at this point.
That's normal discoloration, it doesn't indicate anything other than some use and therefore a bit of getter flash erosion. And it's VERY common on Sylvania made tubes, which is what those are.
Old 20th October 2010, 01:31 AM   #12
diblet is offline diblet  United States
Originally Posted by bob91343 View Post
Diblet, I gave you the answer on AudioKarma. Two bad capacitors.
yeah, i appreciate it. i posted on both forums yesterday - cool to see everyone brought up the similar issues.
Old 20th October 2010, 01:33 AM   #13
ah thanks, that is good to know
help troubleshooting gradually distorting tube amp (dropping b+ voltage when hot)Hide this!Advertise here!
Dropping rectifier filament voltage Nightpuma Tubes / Valves 13 2nd February 2009 10:55 AM
Location of voltage-dropping power resistor hollowman Power Supplies 21 5th December 2008 08:13 PM
dropping heater voltage jarthel Tubes / Valves 17 21st September 2006 04:50 AM
Why is my MOSFET dropping so much voltage? arnoldc Power Supplies 19 21st April 2006 07:52 AM
