diyAudio Sponsor
Old 17th October 2010, 07:05 AM   #1
wushuliu's Avatar
Default AIKIDO LV WON'T START
Okay, this is pretty much my first foray into tubes although I've done my share of DIY on other fronts. I've got an Aikido LV w/ 12BH7 and 48v .52A Jameco Meanwell wall-wart. I powered it up, nothin' happened, then I realized I forgot to bridge the heaters in series. Did that on the 'test bench' and things got a-glowin' okay. When I moved the Aikido over to my gear and powered up (admittedly with the switch on already), nothing. And I haven't been able to get anything to happen since.
The board is simple and I've looked over the solder job and wiring and PS, etc. I've used my DMM and get 48v exact reading from each tube, so something is happening. The tubes are rated for 300mA or so current so my wall-wart should be okay, but I am totally stumped. Any ideas? I got no glow, no nothin' after that one time.
Old 17th October 2010, 08:04 AM   #2
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Wushuliu,
Heaters are nearly short circuit when cold! resistance increases as they warm up so:
You need to give more information. However if you powered the heaters in parallel then they would warm slightly, the resistance would increase then you connected in series the heaters would start O.K.
You then let them cool down and the heater resistance would drop to nearly short circuit so they won't start again. It may be you need a soft start. Try putting a 10 Ohm resistor in series for about 30 seconds then short it out and see if they run up!
You need to measure the voltage from your wall wart when the tube heaters are powered. It may be in current limit. IE. very low volts due to heater "short" due to heaters being cold!
What Voltage are you running your heaters at?
Are the heaters OK not open circuit?
M. Gregg
Old 17th October 2010, 08:31 AM   #3
wushuliu's Avatar
Originally Posted by M Gregg View Post
Wushuliu,
M. Gregg
Hi Gregg, what I am doing so far is checking heater (pin 5) voltage by placing one probe on the (+) of the PS input and the other on the heater pin. I get 48v when I do this. Please let me know if this is the wrong way to check.
Where exactly do I place the 10 ohm in series? With the (+) input voltage?
Old 17th October 2010, 08:36 AM   #4
wushuliu's Avatar
Ok, so you're saying there is a strong current draw which may exceed the wall-wart when turning on, so the resistor 'soft start' would help with this?
Old 17th October 2010, 09:29 AM   #5
M Gregg's Avatar
How are you producing the HT "Inverter"?
The resistor is only in the circuit for 30 seconds it will get hot so you need a wirewound high wattage type 5W or more then short it out with a piece of wire so its not in circuit. If the heaters start then you have your answer!
OK. Tests are:
Power off check the resistance across each of the tube heaters.
If the resistance is O.K. then check the voltage across each heater when powered.(Take care if you have lifted the heaters with HT).
Test the voltage across the heater chain. IE. across the two in series.
Tell us the readings!
M. Gregg
Old 17th October 2010, 09:36 AM   #6
M Gregg's Avatar
The 10 Ohm resistor is in series with the tube heater chain. IE. The + wire to the first tube heater connection. I would turn off the HT until you have solved this problem.
12bh7 heaters are 12.6 volt so two in series would be 25.2 Volt. So how are you reducing the 48V?
M. Gregg
Old 17th October 2010, 11:30 AM   #7
wushuliu's Avatar
M. Gregg
Here's a pic of the the circuit. This is a PCB going straight to a 48v wall-wart smps (linked in the first post), so I'm not sure if turning off the HT separately is do-able. It's late so I'll have a go later in the morning.
Old 17th October 2010, 12:05 PM   #8
RIP
If you are measuring 48v from the PS to all the heater pins that means NO current is flowing. I would imagine that R17 is open.
I don't see a jumper at C1, it won't work without a jumper or switch there.
Old 17th October 2010, 12:26 PM   #9
wushuliu's Avatar
Hi Bill. That pic was just for show, taken before all the wiring. The jumper is in place now. I will check out R17...
Old 17th October 2010, 02:08 PM   #10
M Gregg's Avatar
Now we see Low voltage Aikido.
You don't need the 10 Ohm. R17 does the same job! If you check from ground to junction of R17 and V4 heater then at junction of C1 or link you should have approx half the voltage of supply. If you have full supply then V1 or V3 is open. If this is OK the check between V1 & V3 heater. The current drawn should give a voltage drop across each of the valve heaters.
All tests from Ground
You dont have any HT to turn off!
M. Gregg
Luxman Lv-105 Valerio Solid State 79 15th August 2011 07:36 AM
Luxman LV-105u vs LV-107u Radioman62 Solid State 6 9th November 2010 02:58 PM
start-up sequence of Aikido preamp / SS power amp cbutterworth Tubes / Valves 5 7th May 2007 12:29 PM
Luxman LV-117 ? TroelsM Solid State 0 3rd November 2006 02:10 PM
Luxman LV-105 bra Solid State 1 7th July 2003 07:26 AM
Page generated in 0.13754 seconds (75.59% PHP - 24.41% MySQL) with 11 queries
