#11 |
Bill,
looks to me like he might have lost the heater return. Any thoughts? |
#12 |
Thank guys! I swapped in a 2.2Ohm 10W Eagle resistor for R17 and now they're working. I'm reading 11.8v between heaters and 25,2v at the V3 junction... Is the 2.2 an okay value?
#13 |
Sounds good to me!
Have fun Regards M. Gregg |
#14 |
What value is quoted for R17 in the circuit?
As long as you have 12.6V across each heater + or - 5% it should be OK. Last edited by M Gregg; 17th October 2010 at 05:52 PM. |
#15 |
RIP
I'm sure the turn on surge took it out, 1/4 watt was pretty iffy. A 3 watter would be plenty. The voltages across each tube wont match very well but anything close should work fine. Someone a few years ago did conductance tests on a few different tubes at different filament voltages and concluded that most will operate properly well below their rating. There is always a chance that one will not though, but you should be within 5% as M Gregg said.
#16 | |
#17 |
I'm pretty good at building things, but math is not my strong suit. I'd like to figure out the output impedance of this 12BH7A LV Aikido but I'm stumped by 1) figuring out Rp. How do I get the value? And 2) Parallel lines - Er, what do they and 'in paralell with' mean?:
the formula in the pdf is this: Zo = [rp/(mu +1) + R8] || R13 || [rp + (mu + 1)Rk] |
#18 |
Hey Guys, I know this thread was a year or so ago, but it helped me debug a problem with the LV. It was working on my bench system and then I brought it to a friend's house and hooked it up to his Adcom amp. It worked the first time and then the R17 resistor must have blown. Sure enough, it's open. I'll pick up a 3 watt 1 ohm resistor tomorrow. I've built several of Broskie's pre-amps and love them all. Next project is his SET amp with the Aikido pre in one box. Thanks!
| Luxman Lv-105 | Valerio | Solid State | 79 | 15th August 2011 07:36 AM |
| Luxman LV-105u vs LV-107u | Radioman62 | Solid State | 6 | 9th November 2010 02:58 PM |
| start-up sequence of Aikido preamp / SS power amp | cbutterworth | Tubes / Valves | 5 | 7th May 2007 12:29 PM |
| Luxman LV-117 ? | TroelsM | Solid State | 0 | 3rd November 2006 02:10 PM |
| Luxman LV-105 | bra | Solid State | 1 | 7th July 2003 07:26 AM |
