Under rating of Vertical Sweep Tubes Under rating of Vertical Sweep Tubes - Page 5 - diyAudio
Old 24th October 2010, 12:14 AM   #41
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Back when.... there were no mosfets. A VR tube will work over a fairly wide current range so buffering is not necessary on most circuits. A simple mosfet buffer will however allow the VR tube to function over a small current range improving its regulation.
If you were totally anal you could feed the VR tube with a CCS then LPF it with an RC network and then use a mosfet buffer. Oh, wait a minute that is the circuit that I am using in my Tube Cube amp. I guess that makes me........
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 24th October 2010, 12:17 AM   #42
mashaffer is offline mashaffer  United States
LOL! Tube cube huh? I don't remember that one.
Generic Signature
Old 24th October 2010, 12:43 AM   #43
That's because it isn't finished yet. Life has thrown me a lot of curves lately so I have several unfinished projects. In fact the Tube Cube has been sitting around for nearly a year. It is two Simple P-P boards, each wired for mono PPP, a screen regulator board, a board with 8 constant voltage sinks, a big Antek toroid and two OPT's all stuffed inside a 12 inch cube. It is nearly finished, but I managed to blow up the CVS board about 6 months ago and haven't touched it since.
Important details:
8 X EL84 makes 50 WPC!
Old 24th October 2010, 02:42 AM   #44
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
Originally Posted by mashaffer View Post
Thanks guys. I really appreciate all of the help. BTW when regulator tubes were used as screen regulators they were not generally buffered were they?
Regulator tubes have current limit around 40 mA. If screen grids draw higher peaks when your output tube saturates you will get nasty distortions (sharp peaks of screen grid voltage: VR tubes have negative resistance when switch on/off) instead of saturation that sometimes is forgivable.
In my first Pyramid amp I used SG-4S tube and IRF740 source follower to avoid such a problem.
The Devil is not so terrible as his math model is!
Old 24th October 2010, 02:51 AM   #45
Wavebourn's Avatar
Here are PS PCBs for my Pyramid-VII-M prototype:
Under rating of Vertical Sweep TubesHide this!Advertise here!
Sweep tubes and G3 rsumperl Tubes / Valves 3 5th October 2010 03:54 AM
Do Sweep tubes Glow Blue? wrenchone Tubes / Valves 26 20th July 2009 10:32 PM
Oddball Sweep tubes in PP mashaffer Tubes / Valves 8 4th June 2009 01:17 AM
Some interesting reading about Sweep tubes Vargas Tubes / Valves 2 28th April 2009 04:48 AM
Thoughts on horizontal sweep tubes? DaveCan Tubes / Valves 14 28th August 2008 09:24 PM
Copyright ©1999-2017 diyAudio
