miniblok 1 voltage problem
Old 16th October 2010, 12:34 AM   #1
chopchip is offline chopchip  Canada
Default miniblok 1 voltage problem
i built this amp a while ago and all the voltages checked out, i had 215 volts B+ but now the voltage has bumped up to 250 for some reason and i cant determine why that is. i guess there isnt enough voltage drop across R1 so that means that the tube isnt pulling up enough current, im not sure where to go from here. maybe i can just increase the value of R1 but that doesnt really solve the mystery...
any ideas?
thanks
Old 16th October 2010, 12:10 PM   #2
Cassiel is offline Cassiel  Libya
any ideas?
Yes, leave it alone.
Old 16th October 2010, 12:44 PM   #3
is that supposed to be a joke?
Old 16th October 2010, 12:54 PM   #4
No. No need to worry.
Old 16th October 2010, 01:17 PM   #5
Brit01 is offline Brit01  United Kingdom
I guess if the tube's parameters are within optimum working levels then all should be ok?
Any change in current or sound? Has R2 or R3 drifted?
Have you measured the cathode voltages/current?
If R3 is pulling less current, the B+ is likely to rise.
Old 16th October 2010, 01:30 PM   #6
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
The tube characteristics have changed for some reason. The output triode is pulling less current than it pulled originally. Perhaps it's gassy. Have you tried another tube?
Frank
Old 16th October 2010, 01:55 PM   #7
could it be the bypass cap (c8) next to r3? maybe it's voltage rating is too low because i have the same problem with the other channel's amp.
the sound has become distorted. im going to install a 1ohm resistor from the cathode to ground to measure current.
Old 16th October 2010, 01:56 PM   #8
i tried a different tube and the result is the same. i guess ill just start switching out parts until i hit the fawlty component
Old 16th October 2010, 02:08 PM   #9
Is the bias voltage correct?
Frank
Old 16th October 2010, 02:24 PM   #10
Give us some measurements.
Do you have a DMM?
miniblok 1 voltage problemHide this!Advertise here!
miniblok 2 distorted sound chopchip Tubes / Valves 3 7th October 2010 04:57 PM
Questions about tweaking the Miniblok SET... 69CamaroSS396 Tubes / Valves 11 9th August 2008 08:37 PM
Question about MiniBlok II Schematic pj_cow Tubes / Valves 2 5th March 2008 08:38 PM
High voltage problem jtrompetter Tubes / Valves 8 16th February 2008 05:28 PM
Voltage problem sith Tubes / Valves 10 7th January 2005 12:20 PM
