miniblok 1 voltage problem
Old 16th October 2010, 02:48 PM   #11
chopchip is offline chopchip  Canada
Originally Posted by Frank Berry View Post
Is the bias voltage correct?
is the bias voltage the -35 volts? i measured it at -37v. i guess that is pretty close. the heater voltage is good too. i changed out C8 that didnt make a diff. try C7 next
Old 16th October 2010, 03:01 PM   #12
Originally Posted by Brit01 View Post
Give us some measurements.
Do you have a DMM?
without the tube the caps charge up good, C1 and C2 charge up to 160 volts and C3 up to about twice that much. the voltage on the B+ line is 330 volts.
the bias supply voltage is -37.5volts. heater voltage is 14.25
with tube plugged in B+ is 255v, bias is -37volts and filament voltage is 13.5v.
i will install a 1ohm resistor on pin 3 to ground to determine the current that is going through the tube. will a .5watt resistor suffice?
Old 16th October 2010, 04:08 PM   #13
Brit01 is offline Brit01  United Kingdom
What is the voltage on the plate?
What tube are you using? 13.5 volts for the heater? Is it a 13 series?
To measure current, just measure across the cathode resistor and divide that voltage by the value of the resistor (if it hasn't drifted: measure the resistance of R3 with power turned off to verify).
How did you measure/calculate the bias?
Old 16th October 2010, 04:42 PM   #14
voltage at the plate is 230v on pin 2
pin 1 is 35.6v which is the bias voltage
its a 13em7.
i cant measure the current because there is no resistor from pin 3 to ground. someone said i should mod it with a 1ohm resistor to measure that current.
Old 16th October 2010, 04:52 PM   #15
Yes you can add a 1R resistor to measure current on Pin3 to ground.
I'm doing the same on the cathodes of my OTL in work with a fixed bias.
What current is flowing through R3? Has this changed?
This could have also altered the B+.
If the resistor has drifted down in value then it's going to be pulling more current dropping the B+.
Old 16th October 2010, 05:05 PM   #16
i think the voltages are actually within tolerance if i measure them right at the pins. maybe i can increase R1 by a few values.
i will put that 1ohm resistor from pin 3 and monitor the current there. .5 watt is good?
maybe stalker was right
Old 16th October 2010, 05:20 PM   #17
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
The current through the input section of the tube shouldn't affect the B+ to this extent since the plate of the input stage is fed through a 47k resistor.
The bias voltage is a bit high. I noticed that the 470uf filter capacitors on the bias supply are rated at 35 volts. They're under-rated. Should be at least 50 volts. You might want to bring the bias voltage down a little bit. That will increase the plate current and bring down the B+ voltage a bit.
This is very puzzling.
Frank
Old 16th October 2010, 05:26 PM   #18
if i measure the B+ voltage right at pin 2 it is about 230 volts so i guess that is within tolerance. i was measuring it before the transformer so i guess the transformer drops the voltage by about 30v. kinda silly of me.
i guess it is actually operating properly, i just wasnt measuring the voltage at the right spot. it didnt occur to me that there would be voltage drop across the OT.
the sound was probably distorted because it was turned up too loud and i played some head games with myself.
miniblok 1 voltage problemHide this!Advertise here!
miniblok 2 distorted sound chopchip Tubes / Valves 3 7th October 2010 04:57 PM
Questions about tweaking the Miniblok SET... 69CamaroSS396 Tubes / Valves 11 9th August 2008 08:37 PM
Question about MiniBlok II Schematic pj_cow Tubes / Valves 2 5th March 2008 08:38 PM
High voltage problem jtrompetter Tubes / Valves 8 16th February 2008 05:28 PM
Voltage problem sith Tubes / Valves 10 7th January 2005 12:20 PM
Copyright ©1999-2017 diyAudio
